shootin for 300hp
Discussion in 'Engine Topic' started by gramps, Jan 31, 2011.
  1. gramps
    gramps Veteran Member
    1,488
    897
    Jul 5, 2009
    mankato, mn
    have a few options id like to throw out there and see what you guys bounce back to me.... as the car is torn apart (and will be back together for this spring) need to figure out what im going to do motorwise.
    here is what i have in the 'parts bin' if you will.
    original 350, 85000mi runs like a champ, well 190hp a champ with asthma..
    gm goodwrench 350, 35000mi runs like a champ, ran the block nmbers came back as a 240hp crate replacement motor.
    set of vortec heads solid but need to be cleaned/prepped
    option 1: use the goodwrench motor, put the vortec heads on and run it
    option 2 (and the one im leaning towards): same as above but add a different cam (thinking xe268)
    option 3: put the vortecs on the original motor, run it as is until i gain the coins to have the machine work done to the other motor (clearancing for a 383 kit)
    what do you guys think? on a pretty tight budget otherwise id just do the 383 right away.
    anyguesses as to hp of any of the combos i mentoned?
  2. frankz
    frankz Veteran Member
    2,118
    25
    Aug 24, 2009
    Illinois
    Kinda like the way #2 sounds.........you'll probably like it too.
  3. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
  4. dave bartlett
    dave bartlett Member
    33
    Jan 14, 2011
    indianapolis in
    don't be afraid to port heads I have a stock 305 that with port work flat tops about10-1 comp. 510 hydrlick roller 650 double pumper good ignision that made 430 hp at the crank but I did alot of port work
  5. gramps
    1,488
    897
    Jul 5, 2009
    mankato, mn
    any guesses as to hp that option 2 will make? i was using the comp cams camquest tool and it was saying somewhere around 345 but i am thinking thats probably on the way high side.
  6. frankz
    2,118
    25
    Aug 24, 2009
    Illinois
    Off the top of my head I'd say 325
  7. Marks71BB
    11,833
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    You will reach your target with that set-up.
  8. fun79Z28
    fun79Z28 Veteran Member
    337
    Sep 19, 2008
    Richmond, MI
    I went with the xe268 cam and am very pleased with it. It makes good power off idle and continues through the rpms. My setup makes a lil more power than your hoping to (around 400-410 at the crank is our guess) but Ive got Dart iron eagle platinum heads.
    I think you could make 320-330 horsepower with that cam and the setup youve got nor problems
    Have fun!
  9. SKIP WHITE
    SKIP WHITE Member
    48
    Jan 4, 2010
    Kingsport TN
    Put the Vortec heads on it, and go with cam in the 440-460 lift range as this is about all you do without having a coil bind issue, and for other reasons this cam is about max for this setup. Down the road, invest in a 383 or if your car is light weight, a well built 350 with alum. heads, and you will have it. The best you will see in hp with the 350 you have now and due to other limitations, is about 285-300 hp The Vortec heads will have one thing about them that you will like and it is that they have very impressive bottom end power compared to anything prior to there creation.
  10. z28rod
    4,472
    Apr 30, 2009
    with a good ring job and get her balanced and i bet this will be over 300hp... more like 330hp...
