Thank you. I read a lot on site. I have picked up some good info. I'm going with the tremec 5-speed. I did want the magnum 6 speed but after driving my brothers vette with it although it is nice I don't need a double over drive. I think the 406 will have more than enuf torque to get me thru the 4 gears and with the 3.70 rear in the dana 60 I have already should be very nice. I did have 4.10s in it but swapped them for the 3.70s .kinda wish I didn't now but they will still be nice.Then the od will be the bonus. It's a weekend ride and to car shows . My 406 came in at 10.9 -1 compression. I got [email protected] flat tops,eagle esp rods and a 3.75 eagle crank all balanced. I had 1.5 Harland sharp rockers on it and it's got .840 lifters also. Not going different block although I'd like to but it survived a 150 nitrous blast so I think I'm good with it. I don't plan on any nitrous this go around. I may in future put a procharger on it,but then I susposed I'd be swapping cam again.
Do you have the part number of the rotating assembly you used? That way I can look up the piston specs. I know you mentioned your heads somewhere but don't recall what you said you were running. When it was built was it decked any?
