Smokey15
I'm have trouble getting the door glass to fit properly in the weatherstrip. First problem I had was trying to install door glass that, after spending many hours on, was about 3/16 too wide. So, after getting new glass, it's kicking my butt trying to get it to fit properly. The adjustments were way out of wack from trying to fit previous glass. I have a diagram showing how to adjust glass. I can get it to fit nicely when I shut the door, but when I get inside and try rolling it up it will bind in the weatherstrip on the A pillar, leaving a gap at the top. What I'm wondering is if I have the weatherstrip installed properly.
On the stainless weatherstrip track that the weatherstrip installs in, there is one "channel" for the weatherstrip lip to fit into on the 'outer side". There are two 'channels' on the inner side. One is at the very top and one farther down. I have the weatherstrip in the top one. I removed the weatherstrip from one side of the car. (yes, I trashed a new one) and installed (no glue) a different weatherstrip with the inside in the lower. It looks better but I can't really try to fit the glass without it being fully installed. Which 'inner channel' is correct?
