Silence fuel pump buzzing?
Discussion in 'Engine Topic' started by mc_acoustic, Sep 16, 2015.
  1. mc_acoustic
    mc_acoustic Member
    98
    Mar 3, 2015
    Hey guys, I am a little annoyed by my fuel pump as it buzzes like a little bumble bee...
    I have videos for reference. (yes vids are sideways, just listen thats all)
    Buzzing:
    https://www.youtube.com/watch?v=NgqlLkk5itE&feature=youtu.be
    Fuel pump switch OFF = no buzzing:
    https://www.youtube.com/watch?v=7CqSTKgzk_Q&feature=youtu.be
    I was told by one guy in the city "Just get rubber and put between frame mount"
    Would this work? Does this make sense? I am not quite sure what this means... can anyone explain please?
  2. Overtrained
    Overtrained Veteran Member
    198
    Sep 10, 2015
    Merrick, NY
    What fuel pump is it? And yes, a piece of rubber or gasket if you will bolted between the fuel pump bracket and its mounting surface will help dampen some of the noise.
  3. CorkyE
    11,375
    903
    Dead heading an electric pump? One of the side effects, that noise is your pump straining, trying to push fuel.
  4. Cataldo
    Cataldo Veteran Member Lifetime Gold Member
    2,649
    Jan 16, 2005
    San Bernardino, California, U.S.A.
    Running a return line as opposed to a dead head system is awesome. Noise lever drops significantly. But more portantly it keeps the fuel and the pump MUCH cooler and will allow the pump to live a much longer happier life.
  5. Z28zz383
    Z28zz383 Veteran Member
    839
    15
    May 11, 2012
    Florida
    Get an old tire and cut pieces out of the sidewall, use it under and behind the mounting area. Make the mounting bolts not touch the metal the pump is mounted to. Use washers and oversize holes. Will stop most of the noise. But I have never gotten an elec pump to be quiet enough that you can't hear it when the motor is not running.
  6. joeEZ
    joeEZ Veteran Member
    374
    May 29, 2001
    Memphis, TN USA
    Is it a Holley pump? Holley pumps are loud...
  7. muscl car
    23,345
    1,789
    Jul 8, 2001
    Hendersonville Tennessee
    A aftermarket performance fuel pump that is noisy let's me know it is working .The moment it goes silent then it's something worry about . Ever heard a Aeromotive A1000 pump running ,it's loud !!!!
  8. Z28zz383
    839
    15
    May 11, 2012
    Florida
    My pump was real annoying before the rubber insulators. No metal to metal contact is the key.
  9. Overtrained
    198
    Sep 10, 2015
    Merrick, NY
    My old race car had a BG 280 pump, sounded kind of like that.....then the car fired up and the noise went away lol:crazy:
  10. ssenay72
    ssenay72 Veteran Member
    134
    Sep 21, 2012
    Leominster, MA
