Silverado rattle noise coming from rear of truck.
Discussion in 'The BS Topic' started by TDPalmer, May 29, 2014.
  1. TDPalmer
    TDPalmer Veteran Member Lifetime Gold Member
    823
    Apr 25, 2011
    Cave City, Arkansas
    I posted this on a Silverado forum and haven't had much luck, I was wondering what you guys thought.
    I have this rattle coming from what sounds like the rear driver's side of my truck. It sounds exactly like a card in a bicycle spoke. The noise only happens after the truck has set for 2 hours or more and it'll last for about 5-10 minutes. I will quit at 30 mph and come back anytime below that. I live on a gravel road and it will stop as soon as I hit the pavement, and when I leave work, which is on pavement it will do it consistently for around 10 minutes. I have walked along side the truck and it sounds like it is coming from the driver's side rear wheel area but I am not sure.
    The noise is loud and you can hear it with the windows down and it echos off buildings. It has been driving me crazy trying to fix it .
    So far I have :
    completely replaced the rear end with a new unit with new axles.
    replaced both CV axles
    replaced all brake pads
    replaced the rear driver's side brake caliper.
    lubricated every contact point.
    What could be causing this noise? I am hoping it is not the Sun Gears in the transmission. I would appreciate any input.
    I have a 2004 Silverado with 200k miles with the g80 rear end 17" factory wheels and tire sizes.
  2. Twisted_Metal
    29,702
    2,534
    Someone prank you with a zip tie on your drive shaft?
  3. Mike N
    2,995
    718
    Jan 13, 2002
    Spencerport, NY.
    Parking brake shoe rattling?
  4. Nitroexpress
    Nitroexpress Veteran Member
    1,523
    Jun 1, 2005
    "Rochester" NY
    spare tire loose
  5. TDPalmer
    823
    Apr 25, 2011
    Cave City, Arkansas
    That may be it. any idea on how to tighten it up? If I remember right it just snaps in there.
    To make a long story short I no longer have a spare tire or spare holder..
    There is no zip ties on my drive shaft.
  6. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    The dust covers on the rear brakes rust out real bad on disk brake rear ends, but I suppose you may have already been through those.
  7. dale68z
    dale68z Veteran Member
    1,405
    49
    May 14, 2009
    Peoria Arizona
    Leaf spring clamp. The clampy thingy that typically holds the 2nd leaf to the main leaf. Usually there are 2 on each leaf spring. The clamp will spread and get loose esp if you brake hard a lot. It can be tightened/ bent back into shape with big pliers
  8. millpondmonster
    millpondmonster Veteran Member
    297
    Mar 6, 2012
    far enough out it takes 3 days to get a text messa
    Aluminum or alloy wheels? Check for very small fine crack/cracks. Check lug nuts for correct torque. Check lug holes for wear. Check tire/tires for a flap or cut in the tread face. Seperating belts or seams in the tire. All of these things can cause a noise similar to what you discribe. Just some thoughts.
  9. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    Maybe you have a Wombat stuck to your tire and flopping against the fender and road as you drive.
  10. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Ewwwww.....thats EEEEEEvil
    Gonna get my brothers RAM:crazy:
