Simple Question- Rear axle thread pitch
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ratpatrol71z28, Jul 18, 2016.
  1. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,577
    Mar 29, 2012
    Mantweeka, California
    As title says, what is the rear axle thread pitch?
    I believe 7/16 something..... Reason I ask is because I'm looking to order these lugs hopping to grab more thread through the rims.
    These look correct?
    http://www.ebay.com/itm/252191834871
    Thanks
  2. Bumpad_Z28
    Bumpad_Z28 Veteran Member
    500
    Apr 9, 2004
    Logan, UT
    That is the correct size / pitch 7/16, 20 ...
    But those ET or Extended Tip lugs will only work with certain wheels.
    Make sure the lug nut tip doesn't bottom out / stick through the back of the wheel farther than the "hole depth"
  3. ratpatrol71z28
    1,577
    Mar 29, 2012
    Awesome! I thought so, just wasn't 100% sure..... I checked on my rims and I believe I should have enough clearance. If not, no big deal.
    Anyways, thank you so much for the fast response!
