Since all you guys are lawnmow'n yard equipment gurus, help me out.
Discussion in 'The BS Topic' started by Knuckle Dragger, Aug 10, 2018.
  1. sal70ss
    sal70ss Veteran Member
    2,023
    1,010
    Jan 31, 2003
    Auburn NY
    No fuel issues here. Even storing the mower in the severe cold for six months. I use regular gas
  2. Mike N
    2,996
    721
    Jan 13, 2002
    Spencerport, NY.
    I'm sure that Lucas makes some sort of additive that would suit your needs. Next time you're at Vato Zone buying 02 sensors, check with the expert behind the counter..... :D
    sal70ss likes this.
  3. Twisted_Metal
    29,921
    2,693
    My Cub Cadet is 19 years old and I’ve never had a fuel problem running 87 octane with 10% ethanol.
    It gets used all year for mowing or snow blowing so the fuel never sits in it for more than a month or so.
    My old weed eater had the fuel line soften from ethanol but I replaced the line and never had an issue after that.
    I think most manufacturers are using materials which tolerate the alcohol now.
  4. budro6968
    budro6968 Veteran Member
    3,943
    756
    Apr 2, 2016
    Jax Florida
    My local station has the ethanol free for around 5 bucks a gal last time I checked. I have a 2014 MTD push mower. The carb is plastic. I just use regular 87. I had to pull the carb apart 3 times in 3 years. I replaced the rubber line because I kept getting small black chunks clogging the main jet. No problems since. I have a small yard so I only fill the tank part way to do the job and try to run it dry. Lately though the grass shoots seed stocks 12-15 " long just 2 or 3 days after cutting. I ended up leaving the tank fuller now and I get to mow the front and back twice on a tank. When the season is done I just run dry and cover with roof felt with a big plastic tub on top till next season. I run all my small engines dry. Learned that after some carb replacements especially the weed whacker with the tygone tubes. They crumble in a short time if the regular gas is left in.
  5. sal70ss
    2,023
    1,010
    Jan 31, 2003
    Auburn NY
    Yes the old lady behind the counter at Autozone will give you the best advice if you ask her. Lol
  6. 70 Proof
    70 Proof Veteran Member
    571
    65
    Sep 28, 2014
    Southern Utah
    KD-
    Ethanol free gas is available in Arizona at certain locations. You can do an internet search for ethanol free gas in Arizona to find the location nearest you.
    You can run regular pump gas with ethanol (10% - 15%) in your mower and other 4 stroke engines without any problem as long as its relatively fresh. Small 2 stroke engines like chain saws and weed whips are a lot more sensitive to gas with ethanol in it especially if its been sitting for any length of time. I've found that an additive like Stabil or similar is cheap insurance for any gas that will be stored for a weeks or months.
  7. Todd80Z28
    11,857
    424
    Jun 11, 2002
    Northern VA
    I’ve had my Honda HRX 21” with the GC190 engine since 2005, and I’ve done exactly nothing to it fuel-wise. It gets 87 from the local pump (BJs for the last few years), and hasn’t given me a lick of trouble.
    I change the oil once a year, clean the filter, sharpen the blades and start it up. It’s had one new filter and one spark plug in all that time.
    I have seen the fuel line on a cheap POS John Deere weed eater from a box store eat itself, but this thing was also not cared for in any way. Maybe it was the fuel, or maybe it was just neglect that killed it.
  8. BigBlock73
    2,179
    99
    Jul 10, 2002
    Accord,New York
    I will only put ethanol free gas in all my small engines and Camaro's.
    I run ethanol in daily drivers.
    Here's a site that shows the stations that sell ethanol free gas.
    Find your state at the bottom.
    https://www.pure-gas.org/
    budro6968 likes this.
  9. The Champ
    The Champ Veteran Member
    5,458
    1,084
    Sep 14, 2000
    MN
    KD
    I wouldn't worry one lick about running E10 in anything you buy today.
    The only problem I've ever had is when I didn't run the fuel line empty on a snow blower and let it sit with fuel in the carb for 7 or 8 months. That was over 10 years ago. I now have one rig that I use year round - so no need to worry about E10 related problems.
    As you mow year round, you shouldn't have any problems.
  10. budro6968
    3,943
    756
    Apr 2, 2016
    Jax Florida
    Found The one close to me on the map. About 400 Ft from my house.
