Sinuses... someone needs to figure out..
Discussion in 'The BS Topic' started by Earlsfat, Feb 15, 2010.
  1. muscl car
    23,525
    1,880
    Jul 8, 2001
    Gallatin Tennessee
    i've got sinus problems and my doctor has me on nasonex 50mcg nasal spray and 1 pump in ea nostril per day and it helps some .also since i've got to use a cpap machine i've got one with a vaporizer that i set the temp on at #4 and that really helps
  2. MIDNIGHTBLUE
    MIDNIGHTBLUE Veteran Member
    1,894
    22
    Jul 28, 2000
    Southern Kaifornia
    No offense man......
    Sooo you can snort water but leaning forward and tilting your head head left or right and flushing your sinuses is a no-go? Dude, no offense but do you realize you could die from inhaling SMALL amounts of water?
    You are literally on the edge of aspirating the water (inhaling) or whats called "Dry Drowning".
    I'll stick with the Netti pot.
  3. Todd80Z28
    11,898
    446
    Jun 11, 2002
    Northern VA
    The pot doesn't get the water back far enough to really help me out. I have to get it back to the point where you "feel the burn," and a tiny bit runs down into your mouth. It's easily controlled.
    I suppose I should have expanded on the "I can't do" part. If you've got something that works for you, then do that.
  4. Rickdef17
    Rickdef17 Veteran Member Gold Member
    464
    Aug 27, 2006
    Plymouth MI
    I've been using the Neti-Pot for years. Just makes sense. Just have to relax and let it happen.
  5. rwild1967
    rwild1967 Veteran Member
    251
    Aug 11, 2009
    Look behind you!
    seems like it would be hard to do but it really isn't. it isn't terrible but it does take some getting used to. weird but not painful, and if your doing it right you can get a tiny bit in your mouth. and it really helps!
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
  7. Mountaineer
    Mountaineer Veteran Member
    2,092
    8
    Mar 6, 1999
    Where Mountaineers are free
    The nettipot people also make a squeeze bottle thing that works better, and uses the same solution. Shane, what did they do to your sinuses (surgery-wise)?
  8. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,869
    180
    Aug 18, 2003
    On Wisconsin!
    Lol I have always been bothered by a runny nose... The simple fix was to buy Kleenex stock
    cute story
    after my vasectomy one of the girls in our office, got real curious and wanted to know what happens to the stuff now that the tubes were cut.... I told I wasn't really sure...but I thought the body just absorbed it..... But my nose runs alot more....lmao the look on her face was priceless, especially when I covered on nostril and asked if she wanted a sample
  9. gin man
    gin man Veteran Member Gold Member
    2,331
    135
    Feb 24, 2002
    Morris, Il
    +1
  10. 73RS
    73RS Veteran Member Gold Member
    249
    Mar 7, 2006
    Gonzales LA
    I have had great luck with Simply Saline. It comes in a bottle with a spray nozzle on it so you can direct it right into the nostril. Helps alot with post nasel drip I get also.
