Smartest way to get to a 350?
Discussion in 'Engine Topic' started by FunBobby, Feb 15, 2014.
  1. Smokes
    Smokes Veteran Member
    391
    Feb 5, 2012
    Missouri
  2. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    GM crate motors.
  3. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    Crate 350 is a god way to go.
  4. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    17
    Sep 16, 2012
    NorCal
    You might consider stopping in some local machine shops and see what they have assembled and waiting for a buyer. My experience is they will often have a motor more or less ready to go, and they know what the crate engines are going for on the web ......
  5. RS1979
    4,055
    966
    Jun 18, 2013
    Memphis, TN
  6. ManwithNoName
    ManwithNoName Veteran Member
    165
    Jun 4, 2010
    Lancaster, PA
    This is what I did. My shop had a 355 they had built for some articles in GM High-Tech Performace as a dyno mule. They sold it to me complete for $3k.
  7. fatkid_racing
    fatkid_racing Veteran Member Lifetime Gold Member
    1,049
    90
    Sep 21, 2005
    Saginaw Texas
    Come to Texas and buy mine, it's in the way...
  8. ssenay72
    ssenay72 Veteran Member
    134
    Sep 21, 2012
    Leominster, MA
    About to pull the 350 out of my 81 and replace it, ill sell u that cheap! Its just in Massachusetts. lol
  9. hutchenc
    hutchenc Veteran Member
    345
    Aug 21, 2007
    Wyoming/Colorado
    If you go the crate motor route, look at the L-31 long block 350. It's a factory roller motor 350 replacement motor intended for 1996 to 200 Chevy trucks. Vortec heads, roller cam and lifters. Makes 255 SAE Net HP which is probably about the same thing as the 290 and 300 gross HP flat tappet 350's with worse heads and no roller cam. Same price too (right around $1900).
    Bolt on an intake and carb of your choice and you have a nice motor. Only downside is that they don't have a mechanical fuel pump lobe or boss on the block so you'd have to switch to an electric pump. Not a really big deal though.
    Down the road, if you ever wanted to put a bigger roller cam in it, you could make some pretty good power (350 to 375 HP) with just a cam swap and some small upgrades to the heads (valvesprings, rockers) whereas with the other GM crates, you'd be looking at a cam and head swap to make the same power. A roller cam swap on the other older style blocks will run you at least $750 too so that's a huge bonus with the L-31.
  10. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    Save up buy the 383 short block or long block from GM. THe extra cubes and power are well worth it. Bigger is always better.
    Michael
