Smoke on start up
Discussion in 'Engine Topic' started by '77LT, Aug 25, 2010.
  1. '77LT
    '77LT Member
    45
    Feb 17, 2010
    missouri
    Does anyone know why a big cloud of white smoke comes out the exhaust when i first start up my car?
  2. second2ndgen
    second2ndgen Member
    46
    Aug 14, 2010
    Wentzville, MO
    Is it white smoke or does it have a blue tinge to it? If its oil, your valve seals are bad, allowing oil to collect on top of your intake valves and then when you start the engine, the oil burns. This causes it to smoke on startup.
    Mike
  3. '77LT
    '77LT Member
    45
    Feb 17, 2010
    missouri
    It is just a white smoke
  4. High Country Z
    High Country Z Veteran Member
    1,353
    Jun 28, 2009
    N.Central Pennsylvania,
    Condensation in the muffler.
  5. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    +1 on bad valve seals no doubt
  6. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    valve seals
  7. 1BAD78
    814
    Apr 12, 2007
    Broken Arrow Ok
    My 1980 Chevy Pickup Does It Everytime I Start It. Doesnt Effect The Way It Drives Or Foul Plugs So I Dont Worrie About It.
  8. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    Condensation somewhere in the exhaust. Lot of heat (engine) meets colder denser moist air. See it up here in the winter all the time, starting late fall, lasting until spring. Hot summer nights though you'll never see a hint. If its a lot of white smoke, like it never stops, regardless of exhaust or engine temps, and smells sweet, it could be antifreeze from a head gasket leaking.
  9. sooner
    sooner Veteran Member Lifetime Gold Member
    1,569
    108
    Mar 11, 2009
    Perry,Ok
    valve seals.
    Just think of it as a little extra upper cylinder lube :)
  10. 74Lt1
    74Lt1 Veteran Member
    327
    Aug 30, 2008
    Virginia
    I would say that its valve seals, but if im correct then a blown head gasket can cause like a white steam to come out of the exhaust but i think that it does it even after start up...
