smoking
Discussion in 'The BS Topic' started by rwild1967, Jan 29, 2013.
  1. Da-bigguy
    5,544
    1,425
    Jan 19, 2010
    Cypress, TX
    Good for you man! Keep at it!
  2. red78z
    red78z Veteran Member
    2,353
    Sep 12, 2009
    pottsville,pa.
    i made a promise to Lizzie and my boy that ill quit this year , i never thought quitting would be so hard :whine:
  3. Torrent
    Torrent Veteran Member Lifetime Gold Member
    158
    Jul 26, 2001
    Santiago, Chile
    Believe me, your best decision EVER.
    Keep it up, your mind will try to trick you into believing that you NEED to smoke. It will attack on your weekest moments, you have to stop and think, I can say it's not easy. I used to smoke two packs a day and decided to stop when I was in the middle of a smoke. That's been over 4 years now and I haven't smoked again yet. Don't ever be confident to think that you have quitted and you can stand an occasional smoke or let people smoke around you. Once a smoker, always a smoker and you will never, ever be an ex-smoker, just one who hasn't smoked for a long time.
    I would suggest you to accomplish goals, at first probably a day without smoking, when you are comfortable you will turn it into weeks, then months and years, hopefully it will turn into lifetime.
    also, tell people around you that you are giving up smoking and ask for their support (kinda what you did here).
    Finally, I will be sending you some willpower, it will travel a long way from Southamerica, so give it a good use.
    YOU CAN DO THIS, don't underestimate your enemy EVER.
    GO GO GO !!
  4. Earlsfat
    Earlsfat Veteran Member Lifetime Gold Member
    1,552
    19
    Jun 14, 2006
    Whut?
    Permanent... nicotene is a stimulant. Just don't eat everything and you won't get fat. My pallette opened right the heck up after about 6 months to a year later and I enjoy so many more different foods now.
    Hang tight... it does get better. One thing that helped me was intense cardio (yeah yeah... you can't tell now, but you could a while back.) Being able to breathe nice and deep after running a mile or 2 etc sure makes you realize how bad smoking is. The patch helps with cravings and bad moods... and whatever side effects it could possibly have are so much better than developing lung cancer that not using them as a crutch is a bit of a weak excuse. Quitting smoking is one of the hardest things I've ever done, any and all help... helps, lol.
  5. rwild1967
    rwild1967 Veteran Member
    251
    Aug 11, 2009
    Look behind you!
    Hi guys! Thanks for all the support and advice! I'm at 41 hours and counting!
  6. MrAzzhat2U
    MrAzzhat2U Veteran Member Lifetime Gold Member
    1,397
    Jan 31, 2000
    Lewes DE
    Good Luck Rich,still on my list of things to do!
  7. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Smoking constricts your blood vessels.
    It's really unhealthy for you. You will soon get much more blood flow since your arteries
    and veins will be opening up more. You will feel sooooooo much healthier and your
    body will rest faster now with the increased oxygen flow to everything.
    For Diabetics or pre-Diabetics Dr's advise strongly NOT to smoke because it reduces
    your bodies ability to filter out the sugar, since it constricts all our blood vessels.
    This is why smokers have a higher risk of so many health problems.
    EDIT: Imagine you're at a drag race and your -10AN fuel line gets shrunk to a -4AN fuel line.
    What's gonna happen ??? Fuel pump has to work several hundred % harder to compensate.
    ......just like your heart has been doing for the past X years. It's finally getting a break. :)
  8. BondoSpecial
    8,694
    Sep 20, 2004
    Connecticut
    Other way around. 10AN is bigger (5/8"). AN sizing is defined as the "-" size over a 16th of an inch.
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I knew I was going to screw that up. THanks. :p
  10. rwild1967
    251
    Aug 11, 2009
    Look behind you!
    If BP drops much lower I may be able to get off the hypertension meds.
