So..Do AFR's Eliminators REALLY make power?? Look here.
Discussion in 'High Performance Modifications' started by Rick WI, Jun 12, 2009.
  1. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    rick
    were those race ready or the competition porting version?
    My new engine with the AFR 227 eliminator/ comp port goes to the dyno soon.. we will see how she does.
    mike
  2. Tokyo Torquer3
    2,187
    Oct 14, 2003
    NJ
    by the way.. Mike Lewis/ Lewis racing can get you a few dollars off the AFR's.
  3. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    This was just their basic street head. So, however that comes from AFR. he paid right around 1500 for them.
  4. pastry_chef
    pastry_chef New Member
    Sep 28, 2004
    Ottawa, Ont, Canada
    Hello Rick,
    That is outstanding performance for sure!
    Do you have any more specifics on the Cam such as actual lobe lift and LSA?
  5. Rick WI
    10,400
    Jul 9, 2001
    Madison, WI
    .550 lift, 230 duration, 110 duration, 106 installed. It's a solid Comp Cam although I don't know what lobe the shop owner speced.
  6. onebad82z
    onebad82z Veteran Member
    363
    Sep 21, 2004
    Orange County, NY
    From what I see from Rick WI, street heads for sure!
    :crazy:
    I hear ya bro! Let dem bitches rock!
  7. Tokyo Torquer3
    2,187
    Oct 14, 2003
    NJ
    I figure if you got .550 lift with a 230* solid FT cam, she must be a fairly healthy lobe. what kind of spring pressures are you using? EDM lifters?
    mike
  8. Rick WI
    10,400
    Jul 9, 2001
    Madison, WI
    Mike, I really don't know what all the details are on this engine. Typically Jon will use a spec Isky beehive design he likes in an application like this and spec the lobe based on what has worked in the late models engines that have to run flat tappets. He likely used either a Johnson or Ferrea lifter with a nitriding treatment on the cam. Those combos have been durable in the race engines.
  9. onebad82z
    363
    Sep 21, 2004
    Orange County, NY
