Solo motor swap successful!
Discussion in 'High Performance Modifications' started by hutchenc, Aug 22, 2011.
  1. hutchenc
    hutchenc Veteran Member
    345
    Aug 21, 2007
    Wyoming/Colorado
    Just got my rebuilt 355 in my '72 this evening. It was my first motor swap and I dropped it back in alone (my pop helped me pull it a few weeks back).
    Got the bell housing and Centerforce dual friction clutch from another member here on NastyZ28...everything fit perfectly.
    Specs on the new motor:
    -.30 over ZZ3 shortblock done by Mark Jones (before I bought it). Pretty much a stock bottom end.
    -Isky 272/282 hydro roller, 225/235 at .050 with .505/.530 lift and 112 LSA
    -Stock GM roller lifters with Trick Flow 1 piece pushrods
    -Comp Magnum roller rockers (1.52:1...might swap on a set of 1.6's next year)
    -Pro-Filer 195 heads...64cc combustion chambers, 2.02/1.6 valves, .015 head gaskets for .038 quench...makes for about 9.7:1 compression (lower than what I wanted, but that's life)
    -Weiand Stealth intake manifold, 650 Speed Demon carb (I hope the hood closes...might need a new drop base air cleaner...eek!)
    -1 5/8" full length headers...will be replaced next summer with the 1 3/4" variety...these are beat up pretty good.
    -MSD 8360 distributor and a Mallory coil.
    It had a Vortec 350 in it when I bought her but it was pretty tired. I hope this swap garners some mid-13's for me...I do live at 7200 feet of altitude but the track is around 5000 feet so we'll see.
    All is mated to an M-21 and an 8.5" rear with 3.73's, an Eaton posi, and Yukon axles.
    I hope she starts without any troubles. I did a retro-roller cam and head swap on the 383 in my '56 earlier this summer (same heads, similar cam, but a little more lift). That thing is awesome from 2500 RPM on up with the Pro-Filer 195's...so I hope this 355 doesn't disappoint.
    Here's my ride and the new motor...yep, it looks like every other small block!
  2. 79Berlinetta22
    79Berlinetta22 Member
    88
    Jan 20, 2011
    Houston,Texas
    Very clean ride ! Looks like a sweet driver !!
  3. BB1969
    BB1969 Veteran Member
    270
    Sep 1, 2010
    HILO HAWAII
    Sweet.
  4. BB1969
    270
    Sep 1, 2010
    HILO HAWAII
    Sweet.
  5. theflash
    11,044
    36
    Feb 27, 2004
    Podunk, CT
    Kudos to doing it yourself. That sounds like a pretty nice combo, you should have fun with it.
  6. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,327
    Aug 21, 2002
    Central Coast, CA
    Nice work.
    HMMMMM?.. let's see it!
  7. cgibsong002
    cgibsong002 Veteran Member
    456
    Jun 29, 2010
    Houston, TX
    how long did it take you to drop it back in and get it fully hooked up?
  8. Louich
    Louich Veteran Member
    2,415
    Mar 8, 2004
    Arthur, Ontario
    about time you got your hands dirty :p
  9. Misfire
    Misfire Member
    51
    Jan 27, 2007
    Doraville
    whats a 1 peice pushrod? I have a couple 2 peice pushrod, but had to replace them,OH, i see, you mean at the ends. i was just looking at one of my old one's where the ball had turned and pushed almost in the tube.
  10. hutchenc
    345
    Aug 21, 2007
    Wyoming/Colorado
    I just have the mounts all bolted down at this point (motor and tranny mounts that is). Dropping it in and getting it all mounted took me about 3 hours...I had a few hangups. Probably could have done it in 2 had I not run into a few issues.
    Still have to do the driveshaft and hook up all the electrical. Shooting for a start-up this weekend.
    Still need plugs, anti-freeze, valve covers, and manual transmission fluid.
    Pics of my '56:
    And here they are side by side in the garage:
