mrhand
- May 17, 2022
- 11
I am new to sbc's so please be gentle....I'll have more ?'s as I move a long with this.
I have a roller 350 out of an '87 Iroc Camaro originally a TPI engine. It was an automatic trans car and I plan on putting in a second gen Firebird with a manual trans.
Will I need to give the machine shop the flywheel I plan to use and the harmonic balancer or can I just add them later after the rebuild is complete?
Is this year sbc internally balanced?
Will this '87 block accept the pivot ball stud for the bellcrank the 2nd gen F-bird uses? I thought I saw the hole near the oil filter but I didn't look to see if it was tapped.
Is the back of the crank drilled to accept a pilot bushing since it was originally in an auto trans car?
Is the OEM roller cam in this engine considered a billet core? If so, which fuel pump push rod is correct for it? The 3704817 rod?
