Someone flunked lug nut class
Discussion in 'The BS Topic' started by Dave Nelson, Apr 17, 2020.
  1. Dave Nelson
    Dave Nelson Veteran Member
    5,265
    4,456
    Dec 19, 2003
    Vineland N.J USA
  2. carr911
    carr911 Veteran Member
    3,772
    4,028
    Mar 4, 2016
    Tampa, FL
    less than a 1/2 Mile from where I'm sitting right now
  3. Knuckle Dragger
    16,435
    2,750
    Nov 2, 2002
    Waddell AZ
    We were loosing so many wheels on garbage trucks the city started putting indicators on the lugs so the drivers could see if they were loosening up. Automatic suspension if a car you worked on looses a wheel now, and rightfully so.
    BonzoHansen and gramps like this.
  4. COPO
    20,877
    2,465
    In another city near me, they had idiots going around the neighborhood loosening wheel nuts on cars.
  5. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,848
    980
    May 21, 2014
    Hutto, TX
    That dually tire was like a heatseeker missile. Looked like there was all kind of room in that field/yard but it just had to hit the guy's car. That really sucks.
    Dave Nelson and budro6968 like this.
  6. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    Maybe the spindle nuts came loose and the hub came off. Trying to figure out how the duals were still attached to each other.
    Rusty Shackleford, La.Z8 and Budz like this.
  7. budro6968
    budro6968 Veteran Member
    3,918
    747
    Apr 2, 2016
    Jax Florida
    I have seen Both wheels come off with the axle still attached. This has the drum or disc still bolted by the lug nuts to be together like that. The axle probably snapped off at the flange. Maybe a Bearing seized to the point shearing it off.
    GoldenOne7710 likes this.
  8. Shizzle
    Shizzle Veteran Member
    2,801
    777
    Aug 1, 2012
    oak lawn, illinois
    Those are full floating axles, if the axle snapped it wouldn’t make a difference as the axles are just rotational and not supportive.
  9. roeville
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    Those look like duals off of a Class 8 diesel truck. Not the same. Axle shafts don’t hold the wheels on.
    GoldenOne7710 and budro6968 like this.
  10. budro6968
    3,918
    747
    Apr 2, 2016
    Jax Florida
    Is the axle Basically a tube with spindles attached. Then the Hub or Drum runs on Bearings held by a Nut with a cage? Like a simple Boat trailer type set up, only Heavy duty. I was thinking it was a drive wheel from the Tractor. I watched my buddies F-350 Axle walk out on him after mud bogging. That was on the way home at night. He stopped before it came all the way out. We jacked it up and pushed it back in. Then drove home real slow. It tried to come out a few times. The rear end was chewed pretty bad.
