Someone should ...
Discussion in 'The BS Topic' started by 80sz, Sep 19, 2020.
  1. 80sz
    80sz Veteran Member
    3,452
    515
    Feb 2, 2014
    Buffalo,n.y.
    Come up with a gear set for a Muncie that has 2.52 first , 1.52 second , 1-1 3rd and a .80 4th. Prolly can’t but ya I don’t wanna spend 3500 bucks to get a .82 od.!!! Okay ya I’ll stop dreaming.. be cool tho huh
    1980RS likes this.
  2. xten
    xten Veteran Member
    3,758
    2,591
    Sep 24, 2014
    Pittsburgh, Pa.
    I just talked to the "go-to gear guy" in this area about the same thing. He basically laughed and said yeah, rub a lamp.
    80sz likes this.
  3. jeff swisher
    jeff swisher Veteran Member
    1,699
    553
    Apr 26, 2018
    Yukon Oklahoma
    Lamp was rubbed sort of.
    A833 transmission is what you search for.
    Mopar used them as they came up with it and much later around 1980 GM had stuck some into trucks.
    Research it and I will say it is a pretty strong transmission.
    Yea later ones have OD.
    https://www.allpar.com/mopar/transmissions/four-speed-manual.html
    Then google A833 behind a Chevy.
    My uncle got one at Pull-a-part it was pulled and laying right beside a car and no one around anywhere.
    He pulled the side cover and everything looked perfect. $75
    It was then stuck into his 1967 340 powered Barracuda He got 27 MPG on one leg going back to Oregon from Oklahoma said it was coming out of the mountains.
    His normal MPG was 22-24.
    All timing in by cruise RPM and Ran the Carter 9000 series 625 carb with rear jets swapped into the front.
    I really like that 340 Engine.
    .73 or .71 for OD Ratio
    80sz likes this.
  4. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    3,943
    707
    Mar 13, 1999
    Brighton, MI
    Interesting, I was hunting around a few years ago and ran into articles about the A833, too. But I didn't want to give up the close ratio spacing of the T10 in my Z28. It would probably just be easier to drop the axle ratio down from 3.73 to 3.42.
  5. xten
    xten Veteran Member
    3,758
    2,591
    Sep 24, 2014
    Pittsburgh, Pa.
    Thanks, Jeff. Gonna look into that. I also had a 340 Dart and loved it.
    jeff swisher likes this.
  6. The Champ
    The Champ Veteran Member
    5,158
    934
    Sep 14, 2000
    MN
    Autogear used to make something like that - I think it was called the M22X. They had durability issues and stopped production.
    However, they have the M22Z and the M23Z that have a 2.98/2.99 first gear with a 2.04/2.25 2nd, a 1.47 3rd and a 1:1 4th gear. Just change your rear end gear to higher (lower numerically) ratio and you can effectively get what you want.
    After putting the 462 in my GTO back in 2013, I changed the rear gear from 3.42 to 3.08 in 2015 or 2016 with the plan to eventually put an M22Z or M23Z in. Haven't done it yet, but I think it might happen over the winter.
    Both trannies are brand new with the Autogear Supercase.
    Link to gearsets: http://www.autogear.net/wp-content/uploads/2015/05/Syracuse_modular.pdf
    Link to pricing: https://www.autogear.net/wp-content/uploads/2019/02/Syracuse_Gearbox_Pricing.pdf
    Either transmission will be about half the price of a 5spd overdrive with all the parts you need to complete the conversion. Being a Muncie design, they bolt right up...
    80sz likes this.
  7. 1980RS
    1980RS Veteran Member
    4,598
    1,303
    Jun 17, 2006
    MN
    Screw that crap, I just put a T-56 in my car with 2 overdrives, best thing I ever did for cruzing around. 1700 RPM at 70 MPH is great.
  8. 80sz
    80sz Veteran Member
    3,452
    515
    Feb 2, 2014
    Buffalo,n.y.
    I hear ya just spend the money. I could get that deep first and considering it. I was just looking at the drag set up, the 2.98 is what I need with cam I got. It gets me close to 4.11s with my 3.70s. It hasn’t been a issue with 3.70s and cam so far tho.
    1980RS likes this.
  9. 1980RS
    4,598
    1,303
    Jun 17, 2006
    MN
    I have the GTO T-56 with the 2.97 low gear, it's useless with 4.10 gear and short tires. I now have 3.55's but if I do some engine changes next year to the Vortec 350 in there I may put the deeper gear back in.
    80sz likes this.
  10. dcozzi
    dcozzi Veteran Member
    3,766
    867
    May 1, 2002
    Phoenix, AZ
    If you do any driving on the highway and have the $, go straight to an overdrive 5 or 6 speed. It just cannot be beat. I am still dreaming about getting one.
    My $0.02.
