Someone tell me about "624" heads??
Discussion in 'High Performance Modifications' started by probizjudi, Dec 7, 2006.
  1. probizjudi
    probizjudi Veteran Member
    1,713
    Jun 7, 2004
    Tulsa, OK
    Not sure if Im stating this right, but is there such a thing as 624 heads and if so, can someone tell me some info about them? Do I know what Im talking about, duh? Just trying to find out, thx!!
  2. tonys
    tonys Member
    69
    Jul 25, 2006
    Tuttle Oklahoma
    If your referring to the last 3 digits of the heads this is all I could find on Mortec.
    462624.....75-86...350/400......76cc chamber, 1.72/1.5, 1.94/1.5 or 2.02/1.6 valves
    Hope this is what you are looking for.
    Tony
  3. 79camaro2001
    4,773
    May 4, 2003
    Monroeville, PA
    i got three sets and they are all from trucks, they make decent torque power but they suck still. They are D chamber also.
    I had a set rebuilt then after rebuilding them i went with the vortec heads. better flow, better chambers, after modifying the springs you can run a higher lift cam. and they are cheap compare to other aftermarket heads. but the cost of the new vortec style intake could bust the budget, and the the rocker arms need to self aligning style. unless you run guideplates then you can run non self aligning.
    What your plan with those heads anyway?? the only thing i am going to do with the 624 heads is put them on a mild engine, that i don't care if it makes alot of power.
  4. probizjudi
    1,713
    Jun 7, 2004
    Tulsa, OK
    Well I thought we had GM double humps but a mechanic who is doing some finishing touches on the car said they were not double hump and "looked like" 624's but he wasnt sure unless he could check the casting nbr.
    He said they were a little better than double humps.
    They are on a 406 with a mild cam. More of a "cruisin' " car not a drag car. If ya need more info, let me know & will try to post it.
    Thx for your help!
  5. 79camaro2001
    4,773
    May 4, 2003
    Monroeville, PA
    i wouldn't say 624 heads are better then double hump heads. but it depends on what's been done to it.
  6. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    624s are the worst of the worst... not only are they small valve, low compression smog heads with a detonation-prone chamber design, they are also the VERY crack prone 'light weight' castings.
  7. rustbucket79
    rustbucket79 Veteran Member
    9,076
    May 29, 2003
    British Columbia, Canada
    I will agree that they were crack prone, and most often seen with 1.72 valves on pickups, but they were also standard fair on our Camaros during their production run. They were also on the L-82 Corvette engine with 2.02/1.60 valves and screw in studs and guideplates. Nonetheless, still about the least desireable head, but it terms of performance really no worse than any other GM smogger heads with comparable valve sizes.
  8. Todd80Z28
    11,850
    421
    Jun 11, 2002
    Northern VA
    Yep. These are what came off my motor when I put the trick flows on. Lightweight casting. 76cc, 1.94s in my car.
    Not worth paying for, IMO.
  9. Dirt Reynolds
    Dirt Reynolds Veteran Member Lifetime Gold Member
    3,625
    Jan 17, 2003
    BC, Canada
    The 624 is a light-weight version of the 882, so as Adam and Rust mentioned, basically a crack-prone casting from the smogger era and about the worst of the worst flow-wise and durability-wise.
  10. 79camaro2001
    4,773
    May 4, 2003
    Monroeville, PA
    hence why i didn't run them, but they are sitting on my shelf in a bag covered in oil, and sealed in a box. That way i can run them later on down the road on a low budget engine.
