Something for you guys with the late model GM trucks
Discussion in 'The BS Topic' started by Knuckle Dragger, Dec 2, 2021.
  1. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    https://gm-techlink.com/?p=15389
    Trans thermostat issue. We are seeing a lot of burn up transmissions and odd trans behavior.
    The repair is not covered under warranty. Should be simple to see which thermostat you have
    M1 Master Gunner and Dave Nelson like this.
  2. fbody_mike
    fbody_mike Veteran Member
    1,023
    21
    Mar 24, 2009
    San Gabriel Valley, California
    Thanks for the info. I have a 2020 Suburban, it was a late in the year manufacture so hopefully mine has a 70 on the bottom of the bypass. If not do I then proactively change it, or wait for issues.
  3. biker
    biker Veteran Member
    4,328
    2,137
    Dec 7, 2014
    This is gold. Thanks man.
  4. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    If it were me I'd change it. The fluid in the Tahoes is very dark with under 36k on them.
    I should have a part number for you guys shortly.
  5. djorgensen3
    djorgensen3 Veteran Member
    835
    180
    Oct 15, 2009
    Peoria, Az
    I followed a vid on YouTube to disable that t-stat on my Silverado a few years ago and then added an additional trans cooler and it never gets over 154 degrees even in our summers. It runs real cold in the cooler months but before I did the mod, it would never get below 194 and would get up to 240 degrees pulling a trailer up Sunset Point. I'm glad I did the mod. It also makes it easy to do a trans fluid change now...which I think I am do for again....gahhhh.
  6. Batman
    Batman Administrator Staff Member Lifetime Gold Member
    8,727
    35
    Dec 13, 1999
    Mission Viejo, CA, USA
    So Dave, for my 2015 Sierra, will I need to change the cooler lines as well as someone on the gm-techlink mentioned, or should I be good? Probably should have the fluid changed, since the truck has 145K miles on it!
  7. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    Valve part number is 86774933, seal is 23135703. We have not been able to get a GM part number for the o-rings at the lines. We have either reused the old ones or generic o-rings from a bulk kit.
    Your truck is not listed in the bulletin, I wouldn't worry about it. I personalty don't believe trans flushes do anything positive for modern transmissions. The fluid is generally rated for 100k+. Anymore I believe they are just part of the wallet flush mentality of repair shops. Always consult your owners manual, they may have a different option on this, and I'm sure someone will post up to tell me how wrong I am. :)
    The city did a study shortly before I hired on. They found no significant extension of transmission life by doing the services every 60K as set up in the maintenance schedule at the time. We no longer do transmission services.
    Dave Nelson likes this.
  8. 1980RS
    1980RS Veteran Member
    5,737
    1,951
    Jun 17, 2006
    MN
    I wonder if that was causing the Chevy shake all along on those trucks.
  9. biker
    4,328
    2,137
    Dec 7, 2014
    I've never seen a flush do anything good for an auto trans. In fact, most go the other way for some reason. I like dropping the pan and filter and refilling with new. But as KD says above, new vehicles probably just dont benefit from that anymore.
  10. chevyJeff1
    chevyJeff1 Veteran Member
    853
    107
    Nov 2, 2002
    Shenandoah VA. Listening to the blues
    Was this study only for the fleet trucks that you specialize in? Or a general study on automatics, including cars..?
