Spare tire help
Discussion in 'Original Drivetrain Topic' started by spicewood1, Apr 7, 2011.
  1. spicewood1
    spicewood1 BANNED
    1,936
    Jul 16, 2001
    NC
    I must be stupid. My f60-15 wont come close to going in the trunk far enough for the bolt. What am I doing wrong? Tire goes face up or face down?
  2. Gary S
    22,962
    1,027
    It needs to be in there face down and it should fit. I have one in my trunk, and the bolt fits it that way.
  3. FlaJunkie
    6,354
    238
    Mar 24, 2001
    Rockledge, Florida
    It is the stock wheel, right? If so, it does fit like Gary S says...
  4. Twisted_Metal
    27,518
    1,224
    Do you have aftermarket speakers mounted in the package tray?
  5. FlaJunkie
    6,354
    238
    Mar 24, 2001
    Rockledge, Florida
    Ouch! :eek:
  6. spicewood1
    spicewood1 BANNED
    1,936
    Jul 16, 2001
    NC
    Yes stock tire and wheel and small 6x9 speaker. Problem is I am hitting the inner wheel well AND the seatback frame and still not near centered over the hook. Looks like I need 8 more inches for the bolt to come up through the wheel center.
  7. ls777z
    ls777z Veteran Member
    2,178
    26
    Feb 19, 2000
    Clay,NY
    Wrong bolt ???
  8. fmarullo
    fmarullo Veteran Member
    402
    Mar 29, 2007
    Austin Texas
    You have the incorrect J hook -I had the same issue. The correct J hook is bent; as you have noted, the mount for the hook is not below the wheel center. I scratched my head a few times until I got the correct J hook - problem solved.
  9. FlaJunkie
    6,354
    238
    Mar 24, 2001
    Rockledge, Florida
    Yup. The wheel is not centered over the hold down point...it uses a curved bolt.
  10. R Mitchell
    R Mitchell Veteran Member
    447
    Aug 20, 2008
    Schaumburg, IL
    Here's proof positive that it can be done.
