spark knock
Discussion in 'Engine Topic' started by badazz70z28, Jun 10, 2012.
  1. badazz70z28
    badazz70z28 Veteran Member
    873
    Sep 12, 2004
    mechanicfalls maine usa
    had to change intake on my 454, i know i am off a bit when the dizzy dropped into oil pump shaft, will this cause spark knock?
  2. Noah_Seward
    Noah_Seward Veteran Member
    291
    Dec 9, 2011
    What's your compression? May need to run a higher octane fuel.
  3. 81Dave
    81Dave Member
    44
    Apr 9, 2011
    Kerrville TX
    If you got the timing off a little it could but just readjust it back to where it was before and you should be fine.
    Dave.
  4. Pfrederiksen
    Pfrederiksen Veteran Member
    609
    Feb 21, 2011
    Edmonton,Canada
    Where's your timing at?
    P
  5. badazz70z28
    873
    Sep 12, 2004
    i am running super unleaded.have not thrown a light on it yet, but i know when it dropped in it was not where it came out as i did mark the fiewall, from the mark to where it actually set in was about 1.5 inch diff.
  6. Pfrederiksen
    609
    Feb 21, 2011
    Edmonton,Canada
    Get a light on it.
    P
  7. Gary S
    23,747
    1,428
    Yup. The timing light will tell you the full story.
  8. badazz70z28
    873
    Sep 12, 2004
    ok, reset the dizzy in, set timing at 12 degrees with vacuum advance unplugeed, running 91 octane super, still getting spark knock, more so when it is warm then cold. any ideas ?
  9. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    I am lost on this one
  10. badazz70z28
    873
    Sep 12, 2004
    me too. this is driving me mental. change intake and carb and goes to crap, i want my vega back !!!!!
