Spark plug wire routing
Discussion in 'Tips 'n' Tricks Topic' started by Dennis Wilkie, Sep 22, 2020.
  1. Dennis Wilkie
    Dennis Wilkie Veteran Member
    443
    43
    Mar 17, 2020
    I was attempting to break in my new cam and apparently my #7 & #8 plug wires shifted and laid on the headers, and #8 caught on fire. So, before I buy another set of wires, are there any sets with a little more length or better angles to run them under the tubes? Or am I gonna have to go ahead with the sleeves? It's got ZZ4 heads, so the plugs are angled, which does me no favors on #5 - 8, and i've got a set of looms, but never used them because there really wasn't enough room or length on the wires.
  2. biker
    biker Veteran Member
    4,342
    2,143
    Dec 7, 2014
    Nice looking engine.
  3. Bills69
    Bills69 Veteran Member
    313
    44
    May 28, 2018
    I use Taylor wire looms , vertical or horizontal type , nice clean look
    Zstar likes this.
  4. Twisted_Metal
    30,349
    2,985
    Since you need to buy a new set anyway.... Use a couple of the longer wires from the new set for those two plugs and route them differently.
    You may still need the sleeves to keep the plug boot off the headers with the angled plugs.
  5. Dennis Wilkie
    443
    43
    Mar 17, 2020
    What do you all think about header wraps? Are they worth the trouble? I've read that they don't last and are a pain to put on right
  6. Zspoiler
    Zspoiler Veteran Member
    4,159
    501
    May 6, 2012
    Federal Way, Washington
    I use MSD wire looms with custom fit MSD 8 MM wires ,I use a a heat sleeve on #5 and#5 since it runs really tight .And with a supercharged small block I never had never had an issue,I learned from experience over the years .
  7. xten
    xten Veteran Member
    4,477
    3,561
    Sep 24, 2014
    Pittsburgh, Pa.
  8. 73 Z
    1,175
    73
    Jun 9, 2007
    Los Angeles, Ca
    Angle plugs here, I found it better to run them under headers. Had a top mount metal rail before but it gets real hot from rising header heat and dry's them out on the bottom although the top of wires looked visually good.
    Coadster32 likes this.
  9. Dennis Wilkie
    443
    43
    Mar 17, 2020
    I was running them under the headers until #7 melted & #8 caught on fire. But I just finished the break-in for the cam, and I had to get it up to 35° advanced before the headers stopped glowing red this time...and the # 5 melted from the boot, about 5 inches up, and the plastic wire separator melted between 1 & 3. I used a spring to hold the throttle while I stood over it and supervised everything with the plugs running upward on this attempt. I ordered some sleeve boot protectors that'll be here tomorrow, but I really don't think these should be getting that hot only running at 2500-3000 rpm for that amount of time. Even though they've been on it since I bought it, i'm starting to think this style header is gonna continue to be a problem. But the good news is, both sides were glowing pretty even this time, and once I dropped it to like 2700 and below, you could barely tell they were hot by just looking
  10. biker
    4,342
    2,143
    Dec 7, 2014
    Glad you got it broken in. Some headers may use thicker tubing than others, so thinner ones will glow more easily than thicker ones. Something to look into maybe.
    I think your cam has way more duration than stock. So, it could be creating a mixture/timing condition that the TBI and computer dont have the calibration to compensate for. Might have to get some TBI tuning done?
    Edit: the more I think about it, that cam probably needs more fuel at that rpm than the TBI can provide. Being that lean at that RPM will jack up the exhaust temp as well.
    Scaleytail likes this.
