Spark plugs - feedback on color
roadrace2
1,860
Earth......?
took these out of my GMC pickup - with a crate 350 (stock, with performer edelbrock intake and Holley 600 cfm carb) - had 8000 miles on them.
What's your opinion? Seems like a little contaminates in the fuel system - (red color = rust?) - maybe running lean too?
jeff swisher
1,934
Yukon Oklahoma
From this view they do not look too bad the red is from deposits from the additives they put in fuel.
I pulled some from my 302" Ford that I had set up pretty lean and those plugs looked like you just pulled them from the box after 20,000 miles.
I was running a ported 2 barrel iron intake and a very rough intake runners all the way to the valve seat.
I think your plugs look fine.
You can try and lean it a bit and see what happens with the MPG if you do not see an increase put it back where it was.
roadrace2
1,860
Earth......?
Cool! Thanks Jeff! - Got the timing right, focusing on the fuel now - will lean it out a bit. Fuel economy is important as this is a daily driver.
