spectra efi tank
Discussion in 'High Tech Retrofits' started by bygblok, Jun 11, 2013.
  1. bygblok
    bygblok Veteran Member
    769
    Nov 28, 2010
    Pensacola Florida
    my 70 is an early one and doesn't have any emmisions in the tank. Anything later than that would probably need the emissions(non-vented) type
  2. weircc
    weircc New Member
    23
    Jan 9, 2010
    richmond mo
    I'm about to pull the trigger as well does anyone know if these tanks are fixed? Thought they was having problems when turning corners. I knew they was starting to baffel them. Just didn't know if it ever happened or not
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,552
    156
    Feb 2, 2008
    SF
    I was reading that these tanks have a few issues I called tanks Inc and they just approved a 70-73 fuel injection tank and I've heard good things about the tanks Inc
  4. 72BIGBLOCK
    2,552
    156
    Feb 2, 2008
    SF
    I read the same thing at chevelle forums.
    Tanks Inc will have a Efi tank in 3-4to months and its priced well
  5. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    I purchased the Spectra tank juat a few months ago for my 70 w/ LS swap. Performs flawlessly...I have had zero issues with it except the fact that it is a NON emission tank and it swells up while I am driving it. When I take the cap off it releases, I called Spectra to see about this, and they told me it was 100% normal on non emission tanks. On long drives I get a "film of gas mist" on my back bumper and tail panel, which drives me nuts, but that is my ONLY complaint. Good Luck.
  6. James Kirk
    James Kirk New Member
    8
    Jan 18, 2012
    Owensboro, Ky
    Sev are you venting it properly? A tank should NEVER swell up. Thats a bomb waiting to go off!!!
  7. 70 gsconvt
    70 gsconvt Veteran Member
    1,095
    Sep 30, 2009
    Wadsworth, OH
    X2 ! ! !
  8. kboxx
    kboxx Veteran Member
    149
    Dec 12, 2010
    Bellingham, WA
    I have a Spectra EFI tank too and I would really recommend NOT driving that car until you have that fixed. My tank is a 70 non vented tank with a vented cap. I run the Corvette pressure regulator and have it mounted back by the tank. I am running an LS2. When I remove my cap I get the sucking sound a bit but that is really bad juju to have your tank swell. I would investigate why the tank is building pressure. I'd start by changing gas caps.
  9. cdorhout
    cdorhout Veteran Member
    171
    Jun 29, 2010
    Des Moines, IA
    I have the Spectra tank with the emissions ports on it. I just plumbed the emissions ports to the stock vapor seperator behind the rear seat (71 Camaaro), then the line that orginally went up to the front of the car, I just put a breather on it. It keeps the pressure out of the tank.
    When I first installed the tank, I blocked all those ports off, and I'd get a lot of pressure build up on hot days, and fuel would splash back at me when filling up.
    With the vent it fixed all that.
