Speedometer cable bounce part 2....what I have learned. 79Z
Discussion in 'Troubleshooting & Diagnosis' started by GPN, Jun 19, 2020.
  1. GPN
    GPN Veteran Member
    208
    Oct 5, 2016
    interesting will for check that that connection thank you
  2. CorkyE
    11,280
    863
    One on tail shaft should be metal, it's the "driver". Driven gear will be nylon/plastic.
  3. GPN
    GPN Veteran Member
    208
    Oct 5, 2016
    thank you
  4. biker
    biker Veteran Member
    3,454
    1,542
    Dec 7, 2014
    Plastic driven gear is super easy to replace. Any transmission shop that has been around for a while may have a box full of the old plastic gears. The shop I went to did. Didnt even charge me for it. Just get the same colour gear and swap it in.
    This is assuming yours is bad.. however, look closely at it. At first glance, it may look ok, but on close inspection, if you see a concave profile in the middle of the teeth where the drive gear mates up, that is the problem.
    sandlapper likes this.
  5. GPN
    GPN Veteran Member
    208
    Oct 5, 2016
    my Z is stock 350/4-speed/383 rear end so
    nice---tnx My1979 Z is stock 350/4-speed 383 rear end So drive gear shouldn't be to hard to match up---yes?
  6. rocket dawg
    rocket dawg Veteran Member
    435
    55
    May 5, 2015
    Grand Rapids Mi
    Those plastic gears are available ebay and other places. 3.73 gears makes sense, 3.83 I never heard of ( typo?) a cordless drill on the inner cable at the tranny as suggested will reveal if its a trans problem, keep in mind if the needle isnt moving, you may have to reverse the drill. There are many combos with the gearing so you may need one of these. https://www.ebay.com/itm/1430306333...l8hv3LIjIzOGIuwIgKaEtTlHXY2B0lOQaAkzBEALw_wcB
  7. GPN
    GPN Veteran Member
    208
    Oct 5, 2016
    thx, and yes--typo- 3.83
  8. tomsti
    tomsti Veteran Member
    1,204
    Jul 15, 2003
    Redmond, Wa, USA
    You can drive down the road with the speedo cable in your hand to see if its spinning. If the cop pulls you over you may have a good story.
  9. biker
    3,454
    1,542
    Dec 7, 2014
    I would totally let you off for that.
