SPI epoxy
Discussion in 'Body Restoration' started by 1981zder, Jun 16, 2020.
  1. 1981zder
    1981zder New Member
    Apr 9, 2020
    Question, never used spi epoxy before and wondering if anybody knows if 1 quart of spi mixed 1:1 giving me 2 sprayable quarts if that will be enough to do the underside of a 81 z? No subframe or rear end, just the body. Just trying to do in stages and don’t want the activator going bad.
  2. l16pilot
    2,027
    219
    Dec 13, 2004
    Hurlock, MD, USA
    Just buy a gallon of each...the activator is good for a loooong time if kept in a cool dry environment. I've used it extensively and am really happy with the SPI epoxy.
  3. 1981zder
    1981zder New Member
    Apr 9, 2020
    Thanks
  4. l16pilot
    2,027
    219
    Dec 13, 2004
    Hurlock, MD, USA
    BTW...to answer your other question, I do not think 2 qts ready to spray will be enough. Two wet coats are recommended and there are a ton of little nooks and crannies on the underside which will equal some additional waste trying to get full coverage. I recommended buying a gallon of each to 1) be sure you have enough and 2) you will find lots of other needs and uses for the product and with a long shelf life, I doubt it'll go to waste.
  5. Bandit723
    Bandit723 Veteran Member
    3,561
    640
    Oct 1, 2016
    Waupaca WI
    Found it can be a little finicky when it comes to fish eye's but this stuff looks good and is tough as nails...
  6. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    191
    26
    Oct 4, 2002
    Buffalo,NY,USA
    I never get fish eyes with SPI but I am meticulous with keeping things clean from the earliest stages of prep. Are you sure is not orange peel your getting? If so try turning down the fluid half turn at a time. Try to use a 1.4-1.5 tip if possible and the first coat should be on the light side. I found it easier to adjust fluid backwards from normal and start closed and open fluid half turns until it lays down slick. I've shot gallons of this stuff and it takes a bit to dial it in.
  7. Bandit723
    3,561
    640
    Oct 1, 2016
    Waupaca WI
    I am sure it is not orange peel. I have good luck with items that are sandblasted.
  8. 1981zder
    1981zder New Member
    Apr 9, 2020
    Thanks for the replies. I thought it would only be about a 6 month shelf life once opened, with a year I should be fine. I didn’t think 2 sprayable quarts would be enough but I’ve never used it before so I didn’t know how far it would go.
  9. giggity
    giggity Veteran Member
    1,573
    396
    Mar 18, 2013
    Pearland, texas
    you can actually thin it out depending on application, however I would go 1:1 with frame. Ive used it on my build, its great stuff!
  10. Bob Meyer
    Bob Meyer New Member
    May 29, 2017
    You can go to SPI"s web site to get any information you might need. I used SPI epoxy, 2K primer and their Universal 4000 clear on my 67 Camaro. All their stuff is great. ( http://www.spiuserforum.com/index.php )
    giggity likes this.
