Spoiler paint removal
Discussion in 'Body Restoration' started by BigBlock73, Feb 5, 2021.
  1. badazz81z28
    20,176
    1,282
    Alabama
  2. BigBlock73
    2,170
    93
    Jul 10, 2002
    Accord,New York
    Bad
    This product has been discontinued.
  3. 80sz
    80sz Veteran Member
    3,782
    671
    Feb 2, 2014
    Buffalo,n.y.
    Aircraft stripper still works here in NY, it’s slower tho than previous version. Da it smooth with180,prime and paint. Don’t have to dig down to the base.
  4. TommyRS70
    TommyRS70 Veteran Member
    1,355
    198
    Jan 31, 2004
    KY
    I used a stripper (the kind in a can, ha!) back in 1976 that gently removed paint and re-paint down to the fiberglass without leaving sand scratches. Used plastic scraper and steel wool. Took time but was effective.
  5. 8pack
    2,768
    199
    Aug 29, 2007
    Western, MA
    NO STRIPPER ON SPOILER!
    When I had my car repainted years ago they used a chemical stripper....within a couple of months the paint bubbled up in a few areas....I never had it fixed, just lived with it but it WILL bubble on you.....
    You can go coarser than 220 (180 or 150) to start and get the first couple of layers off, then switch to 220 before primer. It will go quicker but if you are worried it will go too fast just stick with the 220......
  6. Allison Winn
    Allison Winn Member
    78
    9
    Jan 10, 2021
    Different opinions from different people....
    But I can say for certain- I stripped several spoilers in my years doing this. 3 or 4 stripped with the nasty nasty gel stripper that lights you up if a spec gets on your wrist. Never a problem hurting the fiberglass and never a paint problem later. The 1 I sanded off you could see ghost image of the stripes later. My advice is get stripper
    TommyRS70 likes this.
  7. 70lt1z28
    4,182
    955
    Oct 3, 1999
    Beavercreek, Ohio, USA
    always my advice too...wait, what were we talking about?:confused:
  8. G72Zed
    G72Zed Veteran Member
    2,568
    1,177
    Sep 8, 2015
    I did this 100's of times, never an issue, seen cars that were painted 20+ years later.
    Unfortunately, fiberglass or composite fiber sometimes have micro air pockets just under the surface, really need to pay attention and must be careful in neutralizing the stripper as I mentioned. And being the "old" cars prior to the late 80's clean up real nice on the last layer(s)with a good scrub with quality lacquer thinner as most were painted with lacquer or water based enamel, anybody remember liquid feather edge!!!
  9. badazz81z28
    20,176
    1,282
    Alabama
    Many cases it comes down to use. If you put a strong stripper on fiberglass and leave it, yes it will eat it.
  10. BigBlock73
    2,170
    93
    Jul 10, 2002
    Accord,New York
    Thanks for all the advice.
    I've started wet sanding and it's going slow but getting it done. If I had to do more than the center section I would try stripper.
    It's to cold to wet sand outside so the project is on hold for now
