Spoiler paint removal
Discussion in 'Body Restoration' started by BigBlock73, Feb 5, 2021.
  1. Rustbucket350
    Rustbucket350 Veteran Member
    982
    65
    Sep 4, 2013
    Oviedo, Florida
    Strip it with 80 grit on a DA. You're not going to find good paint stripper these days. A few years ago they took the methylene chloride out and now all you can get is a baby version of paint stripper unless you work for someone who has a license to buy it. Don't bother with the shelf stuff now, it sucks.
    I stripped my spoilers with the old aircraft fiberglass stripper. It worked great. These days you won't be able to buy it and that was only 2014 when I did mine
  2. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    I would highly discourage stripping paint off a curvy fiberglass part with 80 grit on a da. That is an aggressive grit AND fiberglass is a soft material vs steel. You will sand through edges right away and still have the interior surfaces to go - you will be through the gel coat and well into reshaping the edge details before all the rest of the paint is off. No matter how good you are with a da....those fine edges will be toast
  3. 70lt1z28
    4,215
    965
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I used 80 grit on a jitterbug. I can finesse a jitterbug much better than a DA around the curves. I hand sand the edges with 180 grit.
    I wanted to leave witnesses of the original stripes to get measurements off of. rear spoiler stripped top view.jpg rear spoiler stripped back view.jpg
  4. Allison Winn
    Allison Winn Member
    89
    12
    Jan 10, 2021
    How did you get in this tight curve?
  5. 70lt1z28
    4,215
    965
    Oct 3, 1999
    On the inside I didn’t, if that’s what you mean. On the outside the sander rolls around it easily. I’m not stripping the underside that is over the trunk lid. No reason. The factory barely painted it. Just overspray. For the ends that hang over the fenders, I’m hand sanding this small areas
  6. Gary S
    23,802
    1,452
    When I put a small fiberglass spoiler on my Camaro, I picked up some chemical stripper from a local body and paint supply shop here. It is made specially for cars like Corvettes. I stripped it and painted it. That was over 20 years ago and it is still just fine.
    I recommend buying a product made for this job, and your local paint and body shops are probably the best place to get it.
