Spring Height Question
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by parker36, Aug 15, 2012.
  1. parker36
    parker36 Member
    98
    Jul 20, 2012
    McCordsville, IN
    I may be jumping the gun here but just thought I would check if anyone knew this answer. I have a 79 camaro that I found after 17 years of sitting in a pole barn. Now the car did not have an engine in it for all those years of sitting. I am redoing the complete front end and bought the eibach pro kit springs. It says a drop of about 1 inch. I took the old springs out and measured them at 17.5" and the new ones that I just got are about 14". That doesn't calculate to a 1" drop if you ask me....but like I said, thinking I may be jumping the gun. Anyone think that those old stock springs have a different measurement after sitting in the car without motor for 17 years or is this something that shouldn't even concern me with thinking about the 1 inch drop they said for this year stock?
  2. gregh
    gregh Moderator Staff Member Lifetime Gold Member
    4,173
    Jun 24, 2003
    Calgary, Alberta, Canada
    You are measuring them with no load on them, not a good way to compare springs because they will compress to a different height(under load) depending on the spring rate(strength).
  3. parker36
    parker36 Member
    98
    Jul 20, 2012
    McCordsville, IN
    Thank you and that is exactly what I was hoping to hear....that I was not doing it right!! That makes me feel much better and thank you again for setting me straight with that answer!
  4. Todd80Z28
    11,857
    424
    Jun 11, 2002
    Northern VA
    What's the part number on the new springs and who makes them?
  5. parker36
    parker36 Member
    98
    Jul 20, 2012
    McCordsville, IN
    The new springs are Eibach and the number is ETB-3852-120.
  6. wayback
    wayback Veteran Member
    1,718
    Mar 5, 2000
    Jungleland, Minnesota
    Greg has it right. Your new Eibach springs are much stiffer than the old stock coils you're replacing. Stiffer springs don't need to compress as far as softer ones do to achieve the correct ride height.
