squeak in rear passenger shock area
Discussion in 'Troubleshooting & Diagnosis' started by Duane McGrath, Jun 30, 2020.
  1. Duane McGrath
    Duane McGrath New Member
    Jun 30, 2020
    look for info on possible issue and resolutions to squeak in rear passenger side area around shock.
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,496
    604
    May 19, 2000
    Los Angeles
    I had a squeak I chased for a while in that same area and discovered it was the parking brake cable housing squeaking against the subframe where it passed through the hole in the subframe. As the rear axle moved up and down, it would move the cable with it, thereby generating the squeak. A little brake grease in that spot cleared that up.
