SS 396 FENDER TEMPLATES 70
Discussion in 'Body Restoration' started by Crazy4camaro, Dec 30, 2020.
  1. Crazy4camaro
    Crazy4camaro Veteran Member
    475
    280
    Dec 30, 2015
    Greenville SC
    Im having trouble finding SS 396 fender templates for a 70 ss 396. SS 350 may be the same.
    Does anyone have a old fender to get factory location. thanks
  2. Gary S
    24,059
    1,575
    The location of the emblems is in the Assembly Manual, but it is almost impossible to interpret them. An original fender to measure would be the best idea as you suggest.
    Crazy4camaro likes this.
  3. Crazy4camaro
    475
    280
    Dec 30, 2015
    Greenville SC
    I have that page, it reference 2 lines.
    0 and 15, not sure how to interpret those numbers on the fender.
  4. ronzz572
    2,396
    209
    Feb 8, 2007
    imperial pa
    My fenders are original on my L78 with factory drilled holes. I will see if I can help here. My fenders are at the body shop about 1.5 hours away. I will reach out to them and see what they can do. But It won't be till next week.
  5. 70lt1z28
    4,437
    1,057
    Oct 3, 1999
    Beavercreek, Ohio, USA
    0 is fairly easy. You drop a plumb-bob around the fender aligned with the center of the top bolt hole in the fender. Kind of hokey, but if you take your time it can work. 15 not a fricken clue. The Views A and B are also worthless. I think I know what the intend, but actually trying to use them to establish the vertical placement would be a leap of faith.
  6. COPO
    21,095
    2,616
  7. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    901
    153
    Aug 14, 2008
    Texas
    Crazy4camaro,
    It is imperative to keep in mind that the measurements are side specific, meaning the measurements for the drivers side are only for the drivers side and you CANNOT simply flip the template over for the passenger side. The passenger side has it's own measurements.
    Good Luck !
  8. COPO
    21,095
    2,616
    Post #6 2nd pic shows the L and R fenders.
  9. Crazy4camaro
    475
    280
    Dec 30, 2015
    Greenville SC
    COPO your pics got me to thinking, I have the Z28 emblems off my 73 z28. I can put decal sticky paper on my z28 to mark line 15 and 0 line
    using the 73 assembly manual measurements to find center. Then put the paper on my 70 ss to have the center lines.
    Thanks to everyone who sent PMS and post on this thread.
  10. jbloake
    jbloake Veteran Member
    424
    106
    May 1, 2002
    Atlantic Canada
    6280950A-DBEA-4374-B4F0-F166572160DD.jpeg A very knowledgable veteran member posted this definition a couple years ago.
    Horizontal 15 line referencing the number of inches from the ride height on level ground with the car at curb weight
