I'm partially installing an SST TKX conversion in my '79 Trans Am (having a shop do the heavy stuff) and am getting close to yanking the brake booster/master cylinder out to install the clutch master cylinder and pedals. I have read here and elsewhere that there should be a dimple in the firewall where the factory hole should be centered, and I presume I should use that as the centering spot for the hole I need to drill, but I haven't found that described specifically for second gens using SST's kit, and their info unhelpfully hits nearly all GM cars but second gens.
I see a couple of folks here have used this hydraulic kit and was hoping that you might chime in on how hard locating the dimple on an auto car was (I can't see the area of the firewall yet, but it feels smooth) and what it took to get the master cylinder rod lined up correctly. I have a set of (presumably) repop'd pedals from SST, and I read about needing to re-drill mounting holes, but we shall see with some trial and error there.
Thanks.
Thanks.
