Stage 1 SBC 350 Brand New 418HP
Discussion in 'Sponsor, Vendors & New Products' started by SKIP WHITE, Jan 31, 2011.
  1. SKIP WHITE
    SKIP WHITE Member
    48
    Jan 4, 2010
    Kingsport TN
    STAGE ONE 413hp SBC CHEVY 350
    COMPLETE FROM INTAKE TO OIL PAN 100% BRAND NEW
    $2,850.00- Lowest price on the market
    THIS ENGINE HAS ZERO REMANUFACTURED OR REBUILT PARTS IN IT. IT'S 100% BRAND NEW FROM TOP TO BOTTOM, INCLUDING THE BLOCK, AS WELL AS OUR HIGH PERFORMANCE ALUMINUM HEADS.[/COLOR]NO ONE OFFERS THE PERFORMANCE AND DURABILITY AT THE PRICE WERE OFFERING THIS ENGINE FOR. THIS IS AN INTRODUCTORY PRICE, AND IS SUBJECT TO CHANGE. THE COMBINATION OF PARTS ARE WHAT MAKE THIS ENGINE VERY UNIQUE.
    NOTE: THESE ENGINES REQUIRE USE OF ELECTRIC FUEL PUMP, THEY HAVE NO FUEL PUMP ROD BORE OR PROVISIONS FOR USE OF A MECHANICAL FUEL PUMP!
    This engine is fully assembled.
    We have come up with the ultimate street/strip sbc engine. It produces [email protected] 5800 rpm and 400lb feet of torque at 4800 rpm. This engine is dyno proven. We use a Super Flo Dyno, the most advanced on the market.
    For the full viewing click here:http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330452759691
    Valve covers, intake, aluminum oil pan, Melling high pressure oil pump kit, chrome over aluminum timing cover are all included, plus hardware. Several valve cover options pictured below. All engine are painted black. The engine below has aluminum roller rockers. We prefer to use the stainless version, due to there exceptional durability. The Hurricane or Typhoon intake, your choice, small head stainless bolt kit included. The Typhoon is very much like the Edelbrock RPM Performer. It's slightly lower for those with low hood clearance. Both of the intakes mentioned above are most likely to tall for the C-3 Corvettes with stock hoods. Pro Products offers a near stock height intake, (Cyclone), but the performance will suffer somewhat. The Typhoon has a better low end throttle response and seems to move the torque range down a bit, but sacrifices about 10hp off the top. This intake is desirable in heavy vehicles or those willing to sacrifice a little off the top, for a better response off the line, or need more hood clearance.
    NOTE: THESE ENGINES REQUIRE USE OF ELECTRIC FUEL PUMP, THEY HAVE NO FUEL PUMP ROD BORE OR PROVISIONS FOR USE OF A MECHANICAL FUEL PUMP.
    The ribbed aluminum oil pan is included, and is not installed. You will also recieve the one inch chrome studded mini nut set, pictured below, to mount the oil pan.
    SFI rated flexplate for use on the one pc. rear main seal engine. These are extreme duty. This item is included, but not installed. As mentioned above these are some of the items that when installed, will prevents us from using the factory crate. A very simple item to install. All hardware included. Pictured below is the Pro Products damper that is included, and hardware. Your choice of 6.75" or 8" size.
    Below are some of the race level components we are using in the engine. Our engines are built and ready to deliver.
    Pictured above are the aluminum heads used on our Stage One engine. Combined with our Crane Blue Racer cam, you will have the highest horse power available in a 350 engine using premium pump gas, while maintaining excellent drivability.
    BUILD SHEET,
    L31 Short block brand new from GM, LT style rods, cast nodular crank, hypereutectic pistons.
    4 bolt main block. One pc. rear main seal design, compatible with all early style GM vehicles.
    Procomp newly revised aluminum heads, 58cc combustion chambers, 210cc runners,
    2.02 race grade stainless valves, one pc. swirl finish, undercut. 2.46 diameter springs with dampers.
    chromoly retainers. We assemble heads at our shop. All gaskets used are Premium series Fel Pro except for the valve covers.
    Our head builder is on of the best in the country in our honest opinion. Our engine builder that installs the heads, has over 15 years experience.
    One pc, chromoly pushrods, 80 thous. wall thickness, no welded ball. True race grade pushrods.
    Our extreme duty Eaton lifters, anti pump up design. Fact without a doubt, a must on any high performance engine.
    Melling high pressure oil pump, (wide neck series)
    Ribbed aluminum oil pan with Fel Pro blue series neoprene oil pan gasket, and one inch studded mini nut set.
    Howards, 488-510 lift. Hydraulic Flat Tappet style, also available with hyd. roller cam.
    Cloyes Tru Double roller timing components. Not to be mistaken with, "double roller only" The Tru double roller timing set is twice the cost of a regular double roller.
    Pro Race harmonic damper/balancer, your choice, on size, 6.75 or 8.00 with damper bolt kit.
    SFI rated 168 tooth flex plate. Made in the USA best grade on the market. Race grade bolt kit included.
    Your choice of five different varieties of valve covers, fabricated also available. One inch studded mini nuts included, as well as our neoprene, steel core valve cover gaskets.
    Your choice of intake manifold. Pro Products, The dual plane Typhoon or Hurricane or Cyclone for those with very low profile hoods such as in the C-3 Corvette. Satin finish. Polished is an upgrade.
    Stainless small head intake bolt kit. Intake gaskets included.
    This engine is brand new, and build to very high standards, and unlikely to ever give you a problem. We would consider the reliability to be very high on this engine. Our testing has more than proven that this engine to be very durable under aggressive driving conditions, not to mention that the Gen Two GM short block built and assembled by GM is one of their most dependable ever built. We have sold many of these in the past, and have had zero failures. You must use an engine oil that has a high level zinc compound in it. There are many such oils on the market, namely most diesel engine oils. If you want to run your favorite engine oil, then you can purchase the zinc oil additive. All engines running flat tappet camshafts must use oils with this additive in them. Premature camshaft wear is inevitable if the oil your using does not have high levels of this additive. Cam break in procedures must also be followed during initial startup on this engine. It is very rare to ever have camshaft problems if the above information is adhered to, but it is very likely you will have problems if this is not the case. The zinc additive must be used at all times, or an oil that has high levels of this compound in it.
    Listed below are items NOT INCLUDED
    NO CARB, NO DISTRIBUTOR, NO WIRE LOOMS, NO HEADERS, NO SPARK PLUGS OR WIRES, NO PULLEYS OR WATER PUMP, NO BRACKETS, NO WATER NECK, NO AIR CLEANER, NO VALVE COVER BREATHERS
    We are willing to bet you will never find it, especially a completely brand new engine with nothing rebuilt or remanufactured.
    Durability will not be a problem, as this engine uses hydr. flat tappet cam, and only has 9.7:1 compression ratio. You can drive it from NY to LA if desired. It's very smooth on the highway. Engine temp is extremely low when cruising, around 165 at night and never exceeds 190 in the day time traffic. Any block that is at standard bore will run cooler than a 30 over and much cooler than a 40 to 60 over. Only in the coolest of climates will a bored block run as cool as a standard and winter time is just not the optimal time for most street rodders.
    The full roller rockers we use are the strongest on the market.
    :cool:
    The pistons are hypereutectic, with LT style pm rods, nodular crankshaft.
    This is the best short block we could have chosen for our Stage One 418hp 350 complete engine. The testing has been very extensive, and somewhat abusive. We are going to run a nitrous setup on the engine next week. Our main goal is to accelerate the engines life span, as well as the car. We will go up to 150hp shot on the nos, and do this repeatablely. If the engine holds up to this total hp of 568 hp, for at least 15 runs, then this is going to be sure proof of it's ability to handle the 418hp from now on. Actually the 6000 rpm range we are taking the engine up to on every run, is more demanding on the engines internals, than anything else we could do. The many hard launches at the track (we are running ET Streets on the car) is also somewhat demanding of the engines crankshaft. Skip claims that if the engine blew up today, we are pretty sure that we have ran the engine as hard as most street rodders would have in a life time, but it's still running as well as the day we first dynoed it. The engine you receive will be identical to what's in Skip’s car, and 100% brand new from top to bottom. Nothing remanufactured, rebuilt, or reconditioned. Just perfectly brand new!
    The heads used are the 23 degree design, Procomps newest series. Intake runner volume is 210cc, chamber volume is 58cc THESE ENGINES CAN BE ASSEMBLED USING STRAIGHT OR ANGLE PLUG HEADS, YOUR CHOICE. These heads have an extra thick deck, hardened intake and exhaust seats with manganese bronze valve guides.
    Give us a call at 423-722-5152 or 877-383-5152 should you have and application issue. We can most likely answer any question you have.
  2. tedm_SS
    tedm_SS BANNED
    90
    Jan 9, 2011
    Missouri
    Thats a good price, how much for the roller cam option? Warranty period?
  3. SKIP WHITE
    SKIP WHITE Member
    48
    Jan 4, 2010
    Kingsport TN
    $2850.00 two year warranty unlimited mileage.
    $295.00 for the Howards Cam upgrade.
  4. GM72_SuperSport
    GM72_SuperSport Veteran Member
    259
    May 31, 2010
    California
    This sounds like a great deal skip. Especially with the roller cam upgrade.
  5. SKIP WHITE
    SKIP WHITE Member
    48
    Jan 4, 2010
    Kingsport TN
    There was a post that started concerning our engines, and it was locked down. It would be a good idea for anyone wanting more detailed info to give me a call at 423-722-5152 or my cell no. is 423-863-9077 This engine is 100% brand new, so there are no isues of reliability. We have sold over 200 of them, and only had one problem in over 3 years.
  6. z28smokin
    z28smokin Veteran Member
    282
    Dec 8, 2004
    Indianapolis, IN, USA
    Many props for being IMHO a stand up guy! It takes a real man to take the criticism you have on this site and give your cell number out! I will not be buying this engine, even though it sounds like a great deal (sorry don't want to lose power). I will purchase items from you if you have what I need in the future. Thanks for your input on this site and I hope you continue to contribute as there are a lot of great guys here that can use your help and will purchase your products. BTW, the more you can support companies like Howards (USA built, high quality, and reasonable price) the more guys here would spend with you. Again that is just my humble opinion.
  7. frankz
    frankz Veteran Member
    2,125
    27
    Aug 24, 2009
    Illinois
    +1
  8. Tirefryer
    Tirefryer Veteran Member
    208
    Jul 18, 2010
    Howell, NJ
    I will be giving you a call.
  9. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    That is cheap for a 400 plus hp sb
  10. 79Cmaro
    79Cmaro Veteran Member
    155
    Jun 18, 2008
    Brooklyn , NY
    F**K!!!!! I Bought a 290Hp Crate from GM almost a year ago!!! WISH i Saw This!!!!
