Starter drags but Want start the car after warm-up
Discussion in 'Troubleshooting & Diagnosis' started by jethro81z28, May 4, 2021.
  1. jethro81z28
    jethro81z28 Veteran Member
    375
    Apr 29, 2002
    silsbee,Tx. US
    first start all’s fine but after it warms up you can try to restart and it R—-R——R like the battery is going dead wait about 15 or so minutes and cranks up. Hadn’t had the problem befor. I just change the tq convert out and it started doing this also when the starter drags I can disconnect the plug-in on the distributor and the motor spends like no problem. It’s got me scratching my head. Any help
  2. Dave Nelson
    Dave Nelson Veteran Member
    5,165
    4,174
    Dec 19, 2003
    Vineland N.J USA
    I'll say bad battery, they do this when cold, but will crank slow when hot.
  3. jethro81z28
    375
    Apr 29, 2002
    silsbee,Tx. US
    I thought the same. But I bought new battery new starter new pos and neg cables and still the same problem
  4. carhead22000
    carhead22000 oldblue
    402
    153
    Sep 5, 2011
    canada
    try a heat shield around your solenoid.that does not work,put a ford solenoid on firewall.tons of instructions online how to wire it.there is plenty of talk on hear somewhere about it...make sure your timing is bang on first.
  5. Dave Nelson
    5,165
    4,174
    Dec 19, 2003
    Vineland N.J USA
    Do you still have your old starter?
  6. jethro81z28
    375
    Apr 29, 2002
    silsbee,Tx. US
    I still have my old starter. I can try putting it back on but why would it spend over with the distributor unplugged ?
  7. Gary S
    23,812
    1,459
    Check your timing. If it is advanced too far, it can drag the starter down when trying to start the engine.
    cadillac_al likes this.
  8. jethro81z28
    375
    Apr 29, 2002
    silsbee,Tx. US
    Initial 12 total 34 all in by 2400 and 54 with vacuum canister
  9. Coadster32
    2,210
    329
    Oct 2, 2013
    Milford,CT
    Headers on these car are know to heat up the starter really good, causing a hot starting issue, Wrapping it with heat shield does help.
  10. jethro81z28
    375
    Apr 29, 2002
    silsbee,Tx. US
    That’s the first thing I did with the new starter. This has me pulling what hair I got left out.
