Starter voltage drop
Discussion in 'High Performance Modifications' started by 74cam, Nov 1, 2008.
  1. 74cam
    74cam Veteran Member
    323
    May 14, 2001
    benton, ms, usa
    Working on the latest pain in the ass. I am trying to diagnos my starter problems and have a question, how much should the voltage drop when you crank the motor over?
  2. Todd80Z28
    11,869
    431
    Jun 11, 2002
    Northern VA
    Do you mean battery voltage? Mine drops down into the low 10.x range when actually cranking, at least initially. I'm using a Honda Civic battery that's 40% lighter than our stock battery, so that's part of the reason.
    I just had to replace a starter due to poor cranking problems. It would drag that battery down into the 8.xx volt range, and crank really slow. I'm guessing the solenoid was going bad in some manner- internal insulation melting off or somesuch. Problem went away completely when I put the new starter on.
  3. 74cam
    323
    May 14, 2001
    benton, ms, usa
    Mine was dropping to the 8 range. But I think I found the problem, Bad connection. Thanks.
  4. Maliboost
    Maliboost Veteran Member Lifetime Gold Member
    7,185
    May 18, 2001
    It should hold 9.5 for 5 seconds of cranking, measured @ the battery.
    Bob
