starters
Discussion in '1974 Specific' started by CamaroNmotion, Oct 4, 2014.
  1. CamaroNmotion
    CamaroNmotion Veteran Member
    389
    42
    Jan 8, 2006
    Buffalo, NY
    Went to replace the starter in my 74 TypeLT Z28 which was the original one to my special ordered, I am the original owner. I ran into problems finding a new build Power Master- retro series which turned out having a alum. nose vs a steel nose which is the original Delco starter has. The alum nose measures 80mm across vs 70mm which is the diameter of the hole in the bellhousing dust cover. I ended up finding a steel nose remanufactured Delco which fit perfectly. I'm planning to rebuild my original Delco unit 1108418 as time permits. My question is did all 74Z28's have the steel nose starters and did the 350 (non-Z28) get the alum nose ones?
  2. Gary S
    23,869
    1,480
    The 4 speed cars used a bell housing with a small hole, and that requires the cast iron starter with the small nose to fit that hole. Auto cars use the standard aluminum nose starter.
    The details of different Chevy starters can be found here.
    http://rmcavoy.freeshell.org/starters.html
  3. 1320racing
    1320racing Veteran Member Lifetime Gold Member
    241
    Jul 30, 2006
    Morehead City, NC
    Keep your original starter, take it to a reliable shop to be rebuilt.
  4. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,170
    92
    Oct 8, 2009
    Emerald Isle , NC
    Was the cast iron nose high torque starter carried over to the 77Z28 when it returned? Just curious.
  5. Gary S
    23,869
    1,480
    From what I can find, the 8418 high torque starter and the 621 bell housing were last used in 1974.
    If the bell housing used after 1974 had the small hole for the starter, it would require a starter with the smaller nose. But, the part number for the starter would most likely be different.
    Those 8418 starters are worth some money today. Original 621 bell housings are almost impossible to get, but they are in such demand that there is a reproduction available.
  6. twozs
    twozs Veteran Member
    8,817
    172
    Aug 5, 1999
    hopewell jct ny
    I just replaced the solinoid on my original .
  7. Z28PILOT
    2,170
    92
    Oct 8, 2009
    Emerald Isle , NC
    Thanks.....I suspected as much .... Discontinued use on Z28 Camaros...although the L82 remained in production as a corvette motor till 1980.
  8. CamaroNmotion
    389
    42
    Jan 8, 2006
    Buffalo, NY
    Thanks Gary. The web site referral has lots of good information.
