Static rocker arm adjustment
Discussion in 'Engine Topic' started by ULTM8Z, Dec 25, 2020.
  1. KingofThings
    KingofThings Veteran Member
    334
    102
    May 8, 2020
    Who?
    I’ll never again do it any other way. Fired immediately as he said and was great!
  2. 1320feet
    1320feet Veteran Member
    415
    180
    Oct 23, 2019
    Calgary, Alberta.
    I'll never do it that way either. With hydraulic lifers on the stand, I would get it done at-least 50% faster than his method. I would bring timing mark to tdc and start at either #1 or #6 cylinder, depending on which one happened to be on compression. I would do both intake and exhaust on that cylinder. I would rotate the crank 90° and do the next one in the firing order, and so on and so on. I typically only use EOIC when a feeler blade is involved.
  3. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    I sell a modified valve cover called an Adjust-A-Cover for adjusting hydraulic lifters on small block Chevy heads.
    I make three different sizes: standard height, tall, and Vortec head style. They come with 8 knockout plugs and directions. $60 plus shipping. PM me if with what style you need.
    KingofThings likes this.
  4. KingofThings
    334
    102
    May 8, 2020
    Somewhere I have little clips that covered the pushrods with a foam plug so you can keep oil under some control. I used to use them to adjust my solids very long ago. I like this idea though. :)
  5. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    Pictures of the three different styles of Adjust-A-Covers I sell.
    1320feet and KingofThings like this.
  6. ULTM8Z
    ULTM8Z Veteran Member
    10,048
    857
    May 19, 2000
    Los Angeles
    That's a pretty neat invention.
    I did get mine adjusted using the static method though, following the valve adjustment order in the link in first post. Worked great... everything is running smooth as silk.
  7. KingofThings
    334
    102
    May 8, 2020
    Interesting idea and they look good.
  8. KingofThings
    334
    102
    May 8, 2020
    The one by Ken?
  9. ULTM8Z
    10,048
    857
    May 19, 2000
    Los Angeles
  10. KingofThings
    334
    102
    May 8, 2020
