Steering Wheel Column
Discussion in 'Troubleshooting & Diagnosis' started by Reginald, Aug 1, 2020.
  1. Reginald
    Reginald New Member
    Jul 21, 2020
    Hello again, I posted a thread a while back about my camaro not being able to start and I figured out the problem, but now there is another, when I'm trying to put the steering wheel back together the column comes up short and I can't seem to get the snap ring back inside the lip and into place, the plate wont go any deeper, any solutions? Thoughts? Thanks again for the big help.
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,518
    634
    May 19, 2000
    Los Angeles
    All I know is it requires a significant amount of force to push that plate deep enough to get the snap ring on.
    Reginald likes this.
  3. Camaro Tim01
    Camaro Tim01 Veteran Member
    227
    38
    Jun 8, 2020
    Bradenton, Florida
    Are you using the steering wheel puller to push down the lock ring ?
  4. Reginald
    Reginald New Member
    Jul 21, 2020
    Yes, I have the tool to push it down, but it still wont go down deep enough to install the lock ring. If I put any more force it it feels like something might break, I have to use pliers after a while as it wpnt turn after a while but still wont go deep enough for the ring.
  5. Reginald
    Reginald New Member
    Jul 21, 2020
    After I use my hands to tighten it, I use pliers on the lock plate puller/installer after a while and it wont keep going after a bit, but it still not enough to get the lock ring into place.
  6. Camaro Tim01
    227
    38
    Jun 8, 2020
    Bradenton, Florida
    make sure the small round plastic piece is thru the lock ring collar and tighten away, it takes ALOT of pressure to get it low enough
