Stock motor mount vs LS Swap
Discussion in 'High Tech Retrofits' started by Revin, Sep 23, 2020.
  1. Twisted_Metal
    28,241
    1,642
    I haven’t done an LS swap but those frame mounts look like the dreaded AutoZone “Performance Mounts”. (A2395)
    The clue is... They only have three mounting holes.
    One of them is in the center at the bottom.
    They bolt up to the frame like they are meant for the car.
    Try as much as you want.... They are different than the stock frame mounts and the engine side mounts won’t line up properly.
    You want part A2292 to replace the stock SBC frame side mounts
    They have FOUR mounting holes (in the corners) but you only use three of them.
    Ask me how I know. :mad:
    Thankfully, you installed them with the nuts on top which makes it a far simpler job to replace them.
    Good Luck!
  2. badazz81z28
    18,846
    996
    Alabama
    The frame kind of fold inward on it self too...it needs to go in straight and pushed down.
  3. Revin
    Revin Veteran Member
    593
    103
    Aug 31, 2016
    Round Rock , TEXAS
    Ok I will go fight it today.
    Those are the"stock"mounts that came with car. V8
    You circled in the pic the space at end of mount. Still ok.
    I guess I will fight a little bit longer maybe take apart the mounts on the frame, and make sure everything's good there and then put it back together and try once again.
    Shouldn't be this hard I don't even have the transmission hooked up to it haha
  4. badazz81z28
    18,846
    996
    Alabama
    Update?
  5. CaliCamaro75
    CaliCamaro75 Veteran Member
    474
    35
    Sep 6, 2015
    Winchester,CA
    I'm curious also
