stock roller lifters 383 520/540 lift?
Discussion in 'Engine Topic' started by fstarocka, Jan 17, 2021.
  1. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    L31 block - Got the bottom end clearanced yesterday and probably going to run with stock GM roller lifters - Ive read of ppl running around .530 with them, I have beehive springs that will be matched and installed at correct height with comp 5/16 pushrods.. Aiming for just near 500hp at 6500 max, this is just a street machine doing short trips..
    The cam (comp XR288) is .540 lift on the exhaust -
    anyone run the stock lifters in a 383 in a regular cam (not small base circle)?
    Option 2 is LS7 lifters -
    1980RS likes this.
  2. CorkyE
    11,393
    915
    I'm using LS7 lifters on ProFiler heads, cam is 590 lift. No issues .
  3. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    Forgot to add this is an L31 block - yours too? saw a hotrod dyno test with one cam down from mine on stock roller lifters- near 500hp.. so think i should be ok- oem GM L31 lifters are good - not sure about pumping up tho-
  4. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
  5. djorgensen3
    djorgensen3 Veteran Member
    801
    168
    Oct 15, 2009
    Peoria, Az
    I am running a Howards roller cam and 1.6 ultra pro magnum rockers totalling 600/610 lift and so far no issues but I haven't revved it yet since its a new motor and currently having carb issues.
  6. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    on stock roller lifters in a sbc/L31? thats about .570 lift on the cam then - far as ive read safe max is around .530- mines at .540 so hopefully it holds.. yours is pushing it :/
  7. djorgensen3
    801
    168
    Oct 15, 2009
    Peoria, Az
    Thats what I read too but as long as the cam isn't a small base circle it seems to be working. I rotated the engine over many times with the intake off to make sure they didn't drop below the dogbones and didn't lift them when at max lift. Lobe lift on my cam is .373/.380 so lifter only moves that distance too.
    fstarocka likes this.
  8. biker
    biker Veteran Member
    3,965
    1,888
    Dec 7, 2014
    My 383 is an L31 block, stock roller lifters, .530/.545 stock base circle Howard's cam. 3 years now, lots of 6300 rpm shifts, no problems.
  9. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    tx biker - perfect ill re-use
  10. biker
    3,965
    1,888
    Dec 7, 2014
    I was picky on measuring the rocker pattern and needed very slightly shorter pushrods, but my deck surface had been milled and I used new aluminum heads. Lifter preload set at 1/2 turn past zero lash.
