Stripped a Head Bolt Hole in my old 406
Discussion in 'High Performance Modifications' started by 1980RS, Apr 7, 2021.
  1. 1980RS
    1980RS Veteran Member
    5,343
    1,721
    Jun 17, 2006
    MN
    Just gave the ARP stud a little test, solid as a rock. Will put the head on after lunch today.
  2. carhead22000
    carhead22000 oldblue
    560
    230
    Sep 5, 2011
    canada
    hopefully after you run engine and retorque it .still be ok...thats when mine failed.goodluck olbuddy.
  3. djorgensen3
    djorgensen3 Veteran Member
    774
    157
    Oct 15, 2009
    Peoria, Az
    My ARP head studs have the hex key hole in them.
  4. 1980RS
    5,343
    1,721
    Jun 17, 2006
    MN
    Well here is what happened with the bolt after lunch. I put the head on and torqued it a bit at #25lbs and it held, but when I got to #45lbs it failed, so plan "B" went into action. I got out the tap set and found a 12X 1.75 pitch metric tap and tapped the hole out and it looked good. I heads over to the local Menards and bought a few bolts as the metric stuff is hardened pretty well. Picked out a couple of stainless bolts and came back to test them, fit perfectly. Now on to the other thinks that came up, I did have to drill the head bolt hole slightly (no biggie) and after that I put the head back on and found that the larger head on the bolt required a 19mm socket to fit, but that will not work on the head as you cannot get the socket on, so out came the bolt. I have a Worksharp sanding disc machine and proceeded to grind down all the flats on the bolt head until a 17mm socket fit right. Put the head back on ran all the bolts down snung inc. the new one and so far so good. 1st pass at #25lbs good on all bolts, 2nd pass at #45lbs good on all bolts, 3rd and final pass all went good and I stopped at bolt 14 and here we go. Made the pull and "click" it worked at #65lbs. on all bolts. Now I have to clean up all the tools and junk just to get one stinkin' bolt to work. Hope the other head is a lot less work.
  5. carhead22000
    560
    230
    Sep 5, 2011
    canada
    glad it worked out for you.
    1980RS likes this.
  6. Twisted_Metal
    29,670
    2,517
    It’s about time that 12x1.75 tap was put to use!
    Hope that bolt holds! <fingers crossed>
    1980RS likes this.
  7. Jodi
    Jodi Veteran Member
    824
    542
    May 22, 2019
    Nice work there 1980RS...IIRC only the first 3 threads on a bolt that's actually doing the most clamping force the rest are just sort of along for the ride LOL. SBC's design of 5 bolts clamping down per cylinder and all those 5 bolts reaching all the required torque value...you should be golden, again nice work!
    1980RS likes this.
  8. G72Zed
    G72Zed Veteran Member
    2,907
    1,413
    Sep 8, 2015
    Good to hear you got this fixed up 1980RS, I feel your pain when that sh!t happens.
    1980RS likes this.
  9. 1980RS
    5,343
    1,721
    Jun 17, 2006
    MN
    Sometimes you just have to use the crap tap to get the job done, Terry. LOL.
  10. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
