stuck/hard to move shifter
Discussion in 'Transmission & Driveline Topics' started by mscamp02, Jul 5, 2010.
  1. mscamp02
    mscamp02 Veteran Member Lifetime Gold Member
    360
    Jan 25, 2010
    Mt Sterling, Ky
    Okay so I recently tried to move my car just so I could get to something else. Anyways its been a while since I started it, probably about 2 months, and it took a bit of work to get it to go into reverse. Needless to say now I cannot get it out of reverse, well not hardly just enough either way to get it to go into neutral but not enough to make it to park or drive.
    the car is a 1981 z with a 700r4 and an old b&m megashifter
    any ideas?
  2. li0nhart123
    li0nhart123 Veteran Member
    737
    Jan 20, 2008
    British Columbia
    i had to crawl under and gently tap the shift rod a bit to get it to move....you may have to take some of the slop out of your linkages.
  3. mscamp02
    360
    Jan 25, 2010
    Mt Sterling, Ky
    alright thanks, its def worth a try
