Stuck Oil Filter Removal
Discussion in 'Tips 'n' Tricks Topic' started by EricsZ28, Jun 11, 2013.
  1. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    My oil filter wouldn't budge. I broke a removal tool trying to get it off, and no luck.
    So, I bought a set of the harbor freight cast aluminum end cap oil filters wrenches (Pittsburgh Automotive - item#69894). These gripped better, but still spun on the filter. So, Plan B...
    I drilled 4 holes in the bottom - the metal is soft, so this is very quick and easy with a hand drill:
    Next, I placed the oil filter wrench on the filter and screwed the wrench to the oil filter. I used 4 self tapping / sealing screws. These are the screws that you would use to attach galvanized siding. With my cordless hand drill and a socket adapter, these went right in. The rubber seals keep the screws from dripping oil...
    Then, turn the oil filter wrench as normal:
    Here are the screws I used. I used a screwdriver to pry the filter out of the wrench, and it popped right off:
    I hope this helps somebody!!
  2. FlaJunkie
    6,433
    248
    Mar 24, 2001
    Rockledge, Florida
    Lesson learned: Don't overtighten the filter when installing it! ;)
    P.S. And use a thin film of oil on the rubber seal before installing it!
  3. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    Yeah, no kidding! I was in a hurry after the refresh at the machine shop and got a bit carried away :innocent:
  4. Krator
    Krator Veteran Member
    381
    Apr 24, 2013
    Drive a screw driver through the side of the filter and twist it. Its a lot quicker and works every time. It will then come off by hand.
  5. 973800CamaroRs
    973800CamaroRs Veteran Member
    702
    Nov 27, 2011
    Frederick Maryland
    Its messy but will work ^
  6. Krator
    381
    Apr 24, 2013
    Yup had to do it on my ridgeline. Last idiot that changed the oil had it so tight I didn't think I could get it off. Moron.
  7. Twisted_Metal
    29,493
    2,389
    Brilliant!!! :cool:
    I've seen the screwdriver trick fail and tear the "can" apart.
    Then... You're left with a real mess to deal with! :mad:
    This method doesn't involve taking an oil bath or a visit to ER!
    I have stamped steel cap wrenches but this should work just as well with them if I ever need it.
  8. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    Thanks. Sometimes the blind squirrel gets lucky and finds a nut :innocent:
    Yeah, I've seen the filters get shredded by the screw driver method as well. A good buddy had that misfortune.
    I'm sure my method has limits, too. Definitely use the metal filter wrench. I stripped a plastic one (where the socket extension went in and on the hex head) trying to get the filter off before I went down this path.
  9. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    P.S. - I also didn't have much room to work around the filter due my headers. Check out the second picture above...
  10. K5JMP
    10,216
    11
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    great idea man!!
    I'll try to remember this next time my step-son changes his mom's oil... wait.. nevermind.. I kicked her to the curb about 2 yrs ago...lol
    still a great idea though:)
