Stumped???????
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by 74cam_mojo, Jul 21, 2004.
  1. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    I have a basterd-ized 74 LT i picked-up in
    Socal....it's NOT the stock engine.....the engine ID is...V0817FSA.....what has me crazy is the FSA suffix???!!! It's a 2 bolt main, Q-jet 4bbl 76"carb, 350 CID. I have no idea what / where it's from????? I'm not mis-reading the number. All reference docs I
    check lead me nowhere....HELP!
    I sound like a GOON when I get parts. help solve this insanity
  2. WS6
    WS6 Veteran Member
    495
    Jan 4, 2002
    Lake Superior-Michigan USA
    FSA is shown as a 3.8L V6
    I find a lot codes FS_, starting with FSB to be 1994 GM truck engines, RPO L05 350/210 hp with manual trans, TBI, used in pickup, van and forward control vehicles.
    I just found a 1984 code FSH, being a 350/165 hp with 4-bbl carb, RPO LS9 used in 1/2 and 3/4 ton trucks. Maybe a A could be cofused with a 'H' by u? or by goon working in engine plant.
    It possible a screwup was done at the engine plant but no reliable sources I have, GM parts and interchanges show it to be a V8 engine code.
    You are going to have to search the block for casting numbers and casting dates, they may help pin down the CID and years used, either 84 or 94.
    Mike
    2002 Trans AM WS6 build #3124 - Pewter
    2004 GMC E. Cab SLT Z71
    [This message has been edited by WS6 (edited July 24, 2004).]
  3. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    sorry about prior / just looked again / had my 12 yr old son (hawk eye) check it's FSA / so your theory re; screw-up atthe factory is making more sense
    thx
    [This message has been edited by 74cam_mojo (edited July 28, 2004).]
