I came to insert the hei distributor today when the washer is the bolt from the u-shape clip that is holding it... Fell inside...
I tried a magnet but it didn't work so after a couple of hours I decided to take off the oil pan. Maybe I'll have luck and find it there of have not access to the cam.
I opened the pan bolts and was hoping to remove the pan but I noticed that the crank counter weight is directed down-side and I don't think that it will leave me enough space to remove the pan. Don't think I can lift the engine that high when it is in the car.
And I'm afraid of rotating it so the cam won't catch the washer...
Any suggestions? Anyone had something similar?
If it's not possible then I think I'll have to remove the manifold/ heads...
