Sub frame connectors?
Discussion in 'High Performance Modifications' started by smallblockchev, Apr 22, 2019.
  1. smallblockchev
    smallblockchev Veteran Member
    365
    Dec 23, 2011
    st michael, mn
    Just rebuilt motor in my 78 Z28, it is now a 383 stroker made 407 horse and 475 ft lbs of torque on the dyno.
    I was told i may need SFC with that kind of torque? if so any recommendations of SFC and what fits the best on a 78 Camaro, 4 speed car with stock drive train.
    Any help appreciated
    Thanks
    SBC
  2. jeff swisher
    jeff swisher Veteran Member
    1,803
    613
    Apr 26, 2018
    Yukon Oklahoma
  3. Bandit723
    Bandit723 Veteran Member
    3,448
    576
    Oct 1, 2016
    Waupaca WI
    Don't buy the competition engineering ones if you have a newer gen2 camaro they won't fit inside your subframe rails without spreading or removing some metal.
  4. smallblockchev
    365
    Dec 23, 2011
    st michael, mn
    Has anyone put on Hotchkis 4013 SFC's ?
  5. RS1979
    4,041
    957
    Jun 18, 2013
    Memphis, TN
    I went with Custom Works. They fit perfectly and work well
  6. smallblockchev
    365
    Dec 23, 2011
    st michael, mn
    I talked with keith sounds like the way i'll go
  7. RS1979
    4,041
    957
    Jun 18, 2013
    Memphis, TN
    You'll also need to use solid frame mounts too
  8. smallblockchev
    365
    Dec 23, 2011
    st michael, mn
    I bought Custom works SFC from Keith back in 2019 just getting around to putting them on now and i need some opinions on how to support the car whether to use jack stands with tires off or use my tire cribs i made with tires on.
    I heard its easier to weld the rears with tires off but where would you put jack stands to support and what would you do for the front? Would like opinions from members who used Custom Works sub frame connectors.
    Thanks for the help
    Smallblockchev
  9. NOT A TA
    NOT A TA Veteran Member
    397
    177
    Feb 12, 2009
    Delray Beach Florida
    I use cribs and if you want to remove the rear tires put the axle on jack stands which will keep the loads in the same places if you keep cribs under the front wheels..
  10. ChevyReb
    4,157
    139
    Feb 4, 2003
    SC
    I would ask Keith but I'm pretty sure he told me to weld them with the weight on the car tires. I think jack stands on axles would be fine but he's a phone call away so reach out. He's probably installed them once or twice. I have the ones he sells and welded mine on the cribs with engine, trans and most of interior except door panels.
