Sub Frame Connectors
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Gasoholic, Jun 25, 2019.
  1. Gasoholic
    Gasoholic Veteran Member
    198
    82
    Apr 2, 2019
    MI
    Looking for some ideas for sub frame connectors for my 78. Wondering what everyone else is using?
    Been looking at the Hotchkiss kit.
    Want something strong, but removeable. If thats even possible?
    Looks like the Hotchkiss ones bolt on the front and weld on the back?
    Any advice before I make a purchase?
  2. badazz81z28
    20,136
    1,279
    Alabama
    If I were to do it all over again, I would still use DSE but bolt them in the front to the frame. Realistically they shouldn’t be bolted in as their purpose is the be structurally strong.
    I personally would only look to Global West, Hotchkis and Detroit Speed.
    hubedobeedo likes this.
  3. badazz81z28
    20,136
    1,279
    Alabama
    Those don’t appear to be 70-81
  4. 79__Z28
    79__Z28 Member
    42
    17
    May 9, 2018
    Longview, wa
    I have the ones from Keith at custom works welded in and they fit good
  5. GoldenOne7710
    5,431
    776
    Jun 23, 2004
    Athens, GA
    I use Competition Engineering bolt-ins. Bolted them in...then had them welded, too. My car is lowered and I've yet to be in a situation where I had ground clearance issues.
  6. muscl car
    23,097
    1,589
    Jul 8, 2001
    SoCal High Desert
    Competition Engineering bolt in subframe connectors then were welded in
  7. Fbird
    5,351
    1,352
    Feb 12, 2011
    atlanta, ga
    piece of 2x3 11 ga and a welder....I'm too cheap to buy that kind of stuff.
  8. dcozzi
    dcozzi Veteran Member
    3,990
    1,021
    May 1, 2002
    Phoenix, AZ
    I used bolt-in CE frame connectors for a few years of 500+HP beatings and the holes never wallowed out or became loose in any way. They seem to be OK bolted in. The part that goes into the subframe bushing is not real thick but, survives just the same.
    I'm welded in now with the GENII units.
  9. 79T/Aman
    2,628
    247
    Oct 7, 2004
    Dickson TN.
    PTFB's GENII frame connectors have the largest minimal cross sectional area of ANY on the market,excelent ground clearance, thickest mounting brackets, they can be bolted in OR welded, they even come with hardware to bolt them in and are the best value. PTFB connector2.jpg
  10. hubedobeedo
    hubedobeedo 3rd times a charm
    613
    222
    Jul 18, 2013
    Huntertown,IN
    i mad mine out of .125 wall 2x3 tubing copy of DSE ,agree with BA about bolting to front instead of welding(only for future removal of sub frame) ,if need be would be easy to cut without getting into connectors or sub frame. had a total cost of 26 bucks in material took about 6 hr.s to do.got alot of tips from hot rod magazine article on F bomb camaro
