Sub-frame connectors.
Discussion in 'High Performance Modifications' started by David Miotto, Aug 27, 2020.
  1. badazz81z28
    18,843
    995
    Alabama
    I have also used Alston Racing with great success. If I was ever to buy another bolt in connector, I would probably go with Hotchkis
  2. dave@ztech
    4,406
    981
    Mar 27, 2016
    NY
    I have a DSE set that I am trying to sell , I went with PTFB’s set and they arrived in a couple of days and they look nice and will be easy to install, I love the DSE concept , however I cannot weld and the price of others to do it were crazy
  3. Lowend
    15,655
    830
    Mar 25, 1999
    San Jose, CA, USA
  4. GoldenOne7710
    5,253
    680
    Jun 23, 2004
    Athens, GA
    Short answer is yes.
    Rule of thumb for a unibody car is that any time you increase the engine output, you will get more twisting of the body. This can crack paint. It can also crack the weld between the roof and top of the quarter panel.
    They can affect the handling of the car too.
  5. Bandit723
    Bandit723 Veteran Member
    3,343
    515
    Oct 1, 2016
    Waupaca WI
  6. Lowend
    15,655
    830
    Mar 25, 1999
    San Jose, CA, USA
    That's Chris Alston's Chassis Works, an entirely different company based in a different state. Not affiliated in any way
    procharged81 likes this.
  7. SPG
    SPG Bumblebee Builder
    787
    233
    Sep 1, 2018
    Sacramento
  8. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    230
    171
    Feb 5, 2016
    Sarasota,FL
    I installed the Hotchkis connectors, no floor pan mods necessary and the most low profile I could find.
    Can be bolted in but I welded mine in. The have worked very well for me.
  9. Bandit723
    3,343
    515
    Oct 1, 2016
    Waupaca WI
    got it thanks..
  10. muscl car
    22,775
    1,361
    Jul 8, 2001
    SoCal High Desert
    As mentioned previously im running competition engineering bolt in subframe connectors that are also welded in . I also had a 8 point cage installed and one of the tubes on ea side of the main hoop is welded to the subframe connectors . Also to further stiffen up the chassis the front bars are tied into the front subframe
