subframe connectors 1981 z28 t top
Discussion in '1978 - 1981 Specific' started by geronimo, May 31, 2021.
  1. geronimo
    geronimo New Member
    18
    May 22, 2021
    I have a 81z with t tops and so far every subframe connectors I've tried hit the rear floor and I cant mount to the rear. I was trying to stay away from weld on but not out of the question anyone have a option that may work with the deeper floor ?
  2. Gary S
    24,000
    1,549
    Some years ago I helped my Son put a set of Competition Engineering bolt on subframe connectors on his 80 Z28 with T Tops. They fit just right without hitting the floor.
  3. geronimo
    geronimo New Member
    18
    May 22, 2021
    I
  4. geronimo
    geronimo New Member
    18
    May 22, 2021
    I tried them too still didn't work
  5. Gary S
    24,000
    1,549
    I"m surprised they don't fit. The 80 and 81 bodies should be exactly the same. Is is possible that your car body has sagged lower than original? T Top cars are weak in the center and do sag.
    STUCKINCALI likes this.
  6. geronimo
    geronimo New Member
    18
    May 22, 2021
  7. geronimo
    geronimo New Member
    18
    May 22, 2021
    All original metal no rust just a repaint
  8. djorgensen3
    djorgensen3 Veteran Member
    793
    167
    Oct 15, 2009
    Peoria, Az
    Stock rubber body mounts? They are probably worn and need to be replaced with solid mounts if you are going to run the subframe connectors.
  9. geronimo
    geronimo New Member
    18
    May 22, 2021
    Already replaced them
  10. djorgensen3
    793
    167
    Oct 15, 2009
    Peoria, Az
    That's good. There are probably just floor variations from years of use and you just need to jack up that hydraulic floor jack a bit more. "Massage" the floor just a bit until it fits.
    masterpieceinprogress likes this.
