subframe connectors 1981 z28 t top
Discussion in '1978 - 1981 Specific' started by geronimo, May 31, 2021.
  1. 73Z L92
    73Z L92 Veteran Member
    184
    52
    Jan 25, 2011
    Carlos, MN
    Have you looked at the Custom Works sub frame connectors? They mount to the rear frame rail. They have a video in the vendor section.
  2. Francesco
    Francesco Veteran Member
    304
    28
    Jan 9, 2015
    Drummondville, Quebec
    The floors sag? Can you explain. How do you adjust?
  3. Coadster32
    2,260
    357
    Oct 2, 2013
    Milford,CT
    I went with Alstom sub frame connectors on my 79 T-top car. They are tube type. Fit like a glove.
    masterpieceinprogress likes this.
  4. Gary S
    23,926
    1,513
    With T Tops, the body is weak. The entire body can sag including the roof and floor. Eventually, the doors bind up and don't open and close properly.
    Some of that distortion can be corrected and then have subframe connectors added to stabilize the body.
  5. Francesco
    304
    28
    Jan 9, 2015
    Thats understandable. But what if you dont want subframe connectors? Lets say you have some sagging and just want to correct? There are many second Gen T-top cars still around. I dont think everyone installs subframe connectors when they have sagging.
  6. carhead22000
    carhead22000 oldblue
    560
    230
    Sep 5, 2011
    canada
    your car would have to be in rough shape for it to sag.or have had a rough life.i owned 81,s.my t-top did move a bit but my torque box pulled away from body,and it was a bbc car and i treated it like i stole it. if body was sagging that much you would see it in your roof.although i have seen them do it.i seen a friend doing floor work,go for coffee and come back to it not lookin so good.its a great idea to put connecters on it.stick a jack under your front shock jack up car.if the other 3 wheels stay on ground its weak.
  7. Francesco
    304
    28
    Jan 9, 2015
    Interesting information! Maybe eventually i'll install some connectors. Lets say you do, which bushings would you use? poly?, solid? Or regular?
  8. carhead22000
    560
    230
    Sep 5, 2011
    canada
    i used solid,some find them a bit rough.not much ride in our old rigs anyway..
  9. Lowend
    16,390
    1,220
    Mar 25, 1999
    San Jose, CA, USA
    Francesco likes this.
  10. Francesco
    304
    28
    Jan 9, 2015
    The real question here is...What will Geronimo do now? Does this mean he has to jump on the frame master?
    Ken70 likes this.
