Summit racing tubular upper control arms
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 75Maro, Jun 29, 2020.
  1. 75Maro
    75Maro Veteran Member
    526
    53
    Mar 31, 2008
    Dallas,Tx
    Wondering if anyone here has used the summit racing brand of tubular upper control arms on a 2nd gen. From what I read on the website they provide a corrected ball joint angle but don't use a taller ball joint, just a factory replacement. Cross shafts aren't offset either.
    Thanks for the help
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,479
    599
    May 19, 2000
    Los Angeles
    You certainly don't need expensive control arms to see a big improvement in performance for a street driven car.
    I got what many would consider to be "cheap a$$" UCA's (and used on ebay to boot) and frankly I was astounded at how much improvement I got over the factory arms. Performance Online.
    As long as they're good quality construction and can get you about 6 deg caster you'll see a remarkable improvement in handling, steering self-centering, ability to track straight, etc.
    Plus you can't go wrong with Summit in terms of them standing behind their products.
    75Maro likes this.
  3. flht99b
    flht99b Veteran Member Gold Member
    568
    165
    Nov 28, 2014
    Knoxville, TN
    These are Summit uppers on a 71. Rubber bushings, no offset cross shaft, stock length ball joint. Easily obtained 6.2 degrees positive caster with .5 degrees negative camber. 9k miles so far, no problems.
    75Maro likes this.
  4. 75Maro
    526
    53
    Mar 31, 2008
    Dallas,Tx
    Wow those specs are great. What benefit does and offset cross shaft bring, does it just eliminate the shims?
  5. 75Maro
    526
    53
    Mar 31, 2008
    Dallas,Tx
    Also, did they come with that rubber bump stop shown in the picture?
  6. BonzoHansen
    19,955
    1,268
    Jun 1, 2005
    Scott from Hamilton, NJ
    What aftermarket arms use offset shafts? I would think the design of the arms themselves would make offset shafts irrelevant.
  7. 75Maro
    526
    53
    Mar 31, 2008
    Dallas,Tx
    After reading up on the PTFB arms and talking to them about a few items it looks like they use offset shafts on their arms.
  8. 70-camaro
    70-camaro Veteran Member
    2,687
    736
    Mar 25, 2010
    marietta ohio
    I have a pair of PTFB uppers with tall ball joint on the way. Also delrin bushings for the lowers.
  9. flht99b
    568
    165
    Nov 28, 2014
    Knoxville, TN
    Yes, came with the rubber bump stops. These were purchased by a guy several years ago for a project that didn't happen.
  10. rburrow87
    rburrow87 Veteran Member
    135
    45
    Apr 6, 2016
    San Diego, CA
    Interesting, my Summit arms came with offset shafts. I got them this year.
